New Oem Suspension Causing Squeaking.
Posted 27 August 2011 - 12:17 AM
Just wanted to put this out there and see if anyone else has had the squeaking after installing this setup and what may have cured it. I have no problem doing control arms, endlinks, tierods (IN & OUT) but I would rather know what might be causing it to avoid buying everything.
The HD's had kilens installed on them before the ipd blues were put in if that would cause anything, seems very unlikely though.
Posted 27 August 2011 - 01:34 AM
When is the squeaking occurring? Bumps? Turns? ??
You need to give a lot more info before people can help.
Posted 27 August 2011 - 01:58 AM
Did you replace any of the hardware outside of springs and struts? What condition are the spring seats, strut mounts, bolts, etc, in?
Everything on the strut is brand new. Seats, mounts, bump stops, washers, rubber pieces, bolts, nuts... everything.
The squeaking occurs during bumps or slight inconsistencies in the pavement.
If I go over bumps while turning the squeaking is not as noticeable and is definitely quieter.
Sorry I was not clear earlier.
Edited by Tommy., 27 August 2011 - 01:58 AM.
Posted 27 August 2011 - 01:42 PM
79 242 GT*84 F150*96 854R*98 S70 GLT-M*98 V70 AWD*00 V70R
72Chevy K10 Cheyenne*78 242 GT*89 740 TIC*96 855R *97 855R*98 V70 NA*98 V70 XC*98 S70 T5
98 C70 T5m*98 V70R*98 V70R*99 S70 AWD*99 V70R*99 V70R*00 V70R*00 V70 XC*04 V70R
Posted 27 August 2011 - 02:22 PM
96 854R Black IPDStage III, Winter (M56, 99T5 motor, 18T) 19psi, Whites, OBX, Eibach springs, SSQV, Exhaust Cutout, Aem UGO, 17" Peggs etc..
87 Nissian Hard Body with a sweet clutch
98 V70R Saffon AWD, Fresh 18T, RICA Stg II, Porsche BBK Sconeman intake pipe, Mufflers Delete,IPD springs, CX Racing FMIC, Hillman MBC @ 18psi, VR Charcoal Swap, Cai, HKS SSQV, Projectors, 18" Peggs, XC90 Wood steering wheel, Front Lip, Full A/C Delete, Slow and Heavy
Posted 27 August 2011 - 03:03 PM
That said I don't really know. What kind of spring seats did you use?
'96 NA 855 - 111 k - daily driver
'95 R 854 - 177 k
Posted 27 August 2011 - 03:39 PM
Ziptied together S70 with a bitchin shift knob. Wanna buy it?
"Having a fast Saab is like coming out of the closet..sure you might surprise some people, but you're still gay."
Posted 27 August 2011 - 03:48 PM
Posted 27 August 2011 - 05:43 PM
There isn't much OEM about this setup ...
just sayin
All components are OEM or OEM+.... just sayin
Xc90 seats, OEM strut mounts
Did you remove or loosen the inner control arm bolts? If you did, did you preload them when tightening them back up?
Nope didn't touch them for that very reason. Kept the hub and everything jacked up the whole time too to avoid stress on the ball joint and such.
Edited by Tommy., 27 August 2011 - 05:41 PM.
Posted 28 August 2011 - 02:21 AM
Had some time to look at the front end today and the squeaking is definitely coming from the top of the strut itself. I think it is the washer that holds the bump stop is rubbing on the top of the springs. Anyone had this problem and found a solution to it, or will it just go away after time....
