Posted 01 September 2011 - 01:23 PM
I know some just remove the cowl seal & even lift the back of the hood at the hinges. I'm trying to find concrete info on exactly how the engine bay air flow was designed to function; my understanding is that the hood is sealed to force airflow over & then down into the tunnel - so when moving, removing the cowl seal would be a bad thing, no?
I haven't found a universal hood scoop that would work as far as I can tell, I know Falcone slotted his, and 850 Kompressor has a scoop. I'm wondering what is the best path to take here. I'd prefer to build something with an inner run off tray, if I do it at all - I would want it as a year-round solution.
Any thoughts, ideas?
Posted 01 September 2011 - 01:33 PM
Another option is to bend up a heat shield to cover up your manifold and reflect the heat downward.
Posted 01 September 2011 - 01:38 PM
Side note, I removed my cowl seal everywhere except for by the fuse box and after a spirited drive you can see and feel the heat escaping. I have no measurements to compare.
Posted 01 September 2011 - 01:41 PM
TRACstar - wrap each individual runner, then wrap collector.
Posted 01 September 2011 - 01:49 PM
Haven't been able to find anything...
1998 S70 T5 M - Black/Graphite, 239whp/317wtq, List of mods
Live in Canada? Looking for a great deal on Genuine Volvo Parts? PM me for details!
Blackberry unlocking - $10. PM me for details...
Posted 01 September 2011 - 02:12 PM
Posted 01 September 2011 - 02:53 PM
Posted 01 September 2011 - 03:02 PM
Posted 01 September 2011 - 03:07 PM
Posted 01 September 2011 - 03:48 PM
Don't raise the rear of the hood, it will get pretty warm inside with the A/C turned off.
NordicTurbo.nl | Nordschleife Squad
Posted 01 September 2011 - 04:06 PM
Picture doesn't work for me?
Posted 01 September 2011 - 04:17 PM
BlackT5, on 01 September 2011 - 04:06 PM, said:
I see, doesn't work here either...
http://nordicturbo.n...al_DSC00344.jpg
*edit..
Edited by Emiel, 01 September 2011 - 04:18 PM.
#14
Posted 01 September 2011 - 04:53 PM
#15
Posted 01 September 2011 - 05:23 PM
Volvospeed On Google+
#16
Posted 01 September 2011 - 05:28 PM
#17
Posted 01 September 2011 - 05:33 PM
http://cgi.ebay.com/...=item3a50569bbc
#18
Posted 01 September 2011 - 06:12 PM
#19
Posted 01 September 2011 - 06:37 PM
Inconel is nice but difficult to work with and expensive. I've made heat shields out of aluminum to protect a carbon monocoque with reflective gold or silver tape on the inside that worked great, or even just plain aluminum as it is fairly reflective in the first place.
cornellfsae.com
borgwarnerboosted.com
#20
Posted 01 September 2011 - 07:01 PM
