Who Had This Problem
10 replies to this topic
#1 Volvot6
Volvot6
    alex77ae
  • 49 posts
Posted 02 September 2011 - 04:43 PM
what should I do to make it start? im thinking starting fluid?
#2 Zappo
Zappo
    THE ONE UPPER
  • 16,472 posts
Posted 02 September 2011 - 05:11 PM
Can you hear the fuel pump when you turn the key on?
#3 (n)A-GAME
(n)A-GAME
    Chief Investigator
  • 7,667 posts
Posted 02 September 2011 - 06:31 PM
You know starting fluid is for barbecues, right?
2011 Volvo S60 T6 AWD Polestar | 2000 Volvo V70 R AWD
#4 Burn-E
  • 9,572 posts
Posted 02 September 2011 - 06:33 PM
Please don't start multiple threads on the same problem. And the right place for posting these kinds of questions is where your last "My car died" thread was moved to by the mods: in the FWD/AWD 1999-2010 Maintenance forum. <- That link points to your original thread where we tried to work through the problem with you. Let's continue the conversation there.
#5 The Big Tuna
The Big Tuna
    Captain Tow Hook
  • 5,148 posts
Posted 02 September 2011 - 06:56 PM
If you think starting fluid is a valid concern you should be taking your car to a shop
#6 Jaxx
Jaxx
    Sandy Orangina
  • 9,073 posts
Posted 02 September 2011 - 08:25 PM
sounds like your transmission failed... It's a T6, right?
trololol
Nadine | ME7 S70 T5 601 - sold
#7 JVC
  • 9,300 posts
Posted 02 September 2011 - 08:29 PM
uhh, you;re not supposed to jump the car from the battery itself. There are posts in the engine bay for that. AAA Jumped my dads car from the battery and had the same error for SRS something something... AAA paid for it but it fried out some module.
Have you checked for spark, fuel etc?
That sounds similar to what happened to my car when I fried the wiring harness/ecu etc. LOLOL
#8 Burn-E
  • 9,572 posts
Posted 03 September 2011 - 12:03 AM
Is this something new with S80s and modern cars John? I'll be honest I haven't jumped a car that's newer than a 98.
#9 Volvot6
Volvot6
    alex77ae
  • 49 posts
Posted 03 September 2011 - 05:25 AM
i used to work alot on engines. heres what it looks like http://valvoline.com/admin/p58.png
#10 303jrodt5
303jrodt5
  • 565 posts
Posted 03 September 2011 - 06:05 AM
It's not even cranking so obviously starting fluid would not help. Are you sure your jumper pack is fully charged? These cars are very sensitive to voltage and if the battery voltage drops low enough it will set weird codes in modules. The gauges drop when you try to crank, which leads me to think that the jumper pack isn't sufficient enough. Try locking your door and unlocking it WITH THE KEY a few times to make sure it's not an immobilizer issue as well.
#11 JVC
  • 9,300 posts
Posted 03 September 2011 - 06:18 AM
Battery is in the trunk, supposed to jump it from the engine bay.
The problem might be that the jumper pack doesn't have enough juice to jump the car from the back and you need to try to jump it from the front. less cable to loose juice from the battery pack to the starter/etc.
