Help With Na Cams And Timing
please help
142 replies to this topic
#1 dublin14
dublin14
  • 2,716 posts
  • Interests:Track events in NASA/ProAutoSports and dumping money into old Vulva. And one of the VS mods on here put that comment above. Dam kids these days lol
Posted 08 September 2011 - 03:54 AM
So basically right now the Cams are locked with a Dealer Cam tool that I got from a Volvo friend.
My mechanic said the crankshaft is set right now a little too the left of the mark on the oil pump, but he said he cant move all the way too that mark or the piston will hit the valves. What he is he supposed to do from here?
#2 Hoosier Daddy
Hoosier Daddy
  • 622 posts
Posted 08 September 2011 - 04:38 AM
why will it hit valves? is your timing belt still on?
1996 855R
#3 wizzard_al
wizzard_al
  • 241 posts
Posted 08 September 2011 - 04:44 AM
What car? 850 the tab on the oil pump is about 11 o'clock, and that is where you align the crank. On S60 and later, the tab on the oil pump is 12 o'clock, and that is where you align it. I found this out the hard way, using 850 diagram on an S60, ended up one tooth off.
If you have the Volvo tool set for doing cams, there is a strange looking piece in the kit you need to use, here it is in a posting on eBay:
http://cgi.ebay.com/...=item27bdb67354
This goes in a hole that is accessed behind the starter (remove starter) and, from VIDA:
"Position the crankshaft
Remove the starter motor mounting screws. Pull out the starter motor and place it to one side.
Remove the blind cover plug
Turn the crankshaft slightly clockwise.
Install crankshaft stop. Ensure that it bottoms out against the cylinder block.
Turn the crankshaft counter-clockwise until it stops against the crankshaft stop
Check that the marking on the crankshaft timing gear pulley corresponds with the marking on the oil pump."
STop goes in with the projection on the top of the tool when stuck in the hole in the block. Don't lose the seal on the plug.
Now you have the crank and cam indexed properly.
If he is that close, it shouldn't hit the pistons. Of course, you do this with the timing belt OFF.
Edited by wizzard_al, 08 September 2011 - 04:46 AM.
2001 S60 T5 Manual Black/Oak 222K miles; Ultra Racing front, rear braces, iPD front & Evolve rear sway bars, XC90 brakes, gauges
1997 854 GLT NA Manual 192K - son; 1995 854 NA Auto 240K - daughter
#4 dublin14
dublin14
  • 2,716 posts
Posted 08 September 2011 - 11:22 AM
Its a 98 S70T5 and the Belt is off. I have never heard of this tool? So the Cranks and the crank have to be indexed properly, but only these guys on that ebay site have the tool. Im confused?
The T-belt is off.
#5 dublin14
dublin14
  • 2,716 posts
Posted 08 September 2011 - 11:29 AM
The T-belt is off.
View Postdublin14, on 08 September 2011 - 11:28 AM, said:
Or do the dealers have this tool? If so,
#6 dublin14
dublin14
  • 2,716 posts
Posted 08 September 2011 - 01:30 PM
Well my mechanic and a Volvo tech had a talk and figured out everything so far was done right. The problem might be that both the NA cams that were put in are the same cam???? Is there two different part numbers for 93 NA cams??
#7 boxpin
boxpin
  • 835 posts
Posted 08 September 2011 - 01:42 PM
Here is a picture of that tool in action. I had never heard of it either. Just ran across this picture from another post on VS from 07. I probably would not have noticed if it were not for this thread.
13.7 @ 99 Automagic Posted Image 13.8 @ 104 Manual
1995 855M - Quaife, 18T, ARD Blue, Meth, 3" catless, FMIC, N/A(cams & TB), Scone, H&R, Bilstein
#8 dublin14
dublin14
  • 2,716 posts
Posted 08 September 2011 - 01:54 PM
I just talked too Volvo and they never use that tool? Right now the cams are coming back out too see if they were reversed? Thats why im looking for part numbers for reference. FRom what both techs think is that the cams are the same cams, not an intake and exhaust, or the cam were installed backwards? I have NO idea and just hope that i acan get some info and get this thing started.
#9 BlackT5
BlackT5
    NWC Rod Bender
  • 5,769 posts
Posted 08 September 2011 - 02:12 PM
There are markings on the back end (dist/cam sensor side) of the cams that indicate I and E. You don't need to pull the cams to see the markings.
1998 S70 T5M
#10 s_moneh
s_moneh
  • 1,166 posts
Posted 08 September 2011 - 02:48 PM
even if there rn't markings i'm almost 100% sure that the cams look very different on the transmission side, you have the intake cam that holds the distributer and the exhaust cam has the piece for the cam sensor, i'm pretty sure u can tell the difference
#11 BlackT5
BlackT5
    NWC Rod Bender
  • 5,769 posts
Posted 08 September 2011 - 02:53 PM
1998 S70 T5M
#12 dublin14
dublin14
  • 2,716 posts
Posted 08 September 2011 - 03:55 PM
I just called my guy too see if he can find any markings that indicate I and E on the Cams.I cant see then on the pic above though? What a PITA his is.
#13 BlackT5
BlackT5
    NWC Rod Bender
  • 5,769 posts
Posted 08 September 2011 - 03:59 PM
You can't see the markings? The one on the right is hard to see but the one on the left isn't bad. Adjust your monitor? The left one says 9146232.PLI. I indicating Intake. The other one ends in E indicating Exhaust.
1998 S70 T5M
#14 lookforjoe
lookforjoe
  • 8,311 posts
  • Interests:Making Stuff
Posted 08 September 2011 - 04:08 PM
If the pistons are hitting the valves when he rotates to the mark, he must have the cams reversed. The cams are clearly marked as BlackT5 indicated: part # followed by an "I" or "E"
properly installed, the intake slot is over center, the exhaust slot is under center
Oil pump marker should fall between the two notched teeth on the gear (in this pic the base timing for install ONLY was set earlier 'cos of the Enem Cams)
EDIT: For clarity's sake, this is Volvo base setting
This is actual TDC
#15 dublin14
dublin14
  • 2,716 posts
Posted 08 September 2011 - 04:17 PM
Awsome!!! Thats what im lookin for. Thanks.
#16 dublin14
dublin14
  • 2,716 posts
Posted 08 September 2011 - 04:23 PM
Thanks!
#17 lookforjoe
lookforjoe
  • 8,311 posts
Posted 08 September 2011 - 06:43 PM
Added two pics above to show Volvo base setting & actual TDC
#18 dublin14
dublin14
  • 2,716 posts
Posted 09 September 2011 - 04:42 AM
The cams are where they should be now and all seems good. I spent the last 5 hrs getting all together and ready for start up tomorrow :ph34r: :D
#19 dublin14
dublin14
  • 2,716 posts
Posted 09 September 2011 - 01:54 PM
Off topic here.... but right now Im running the AC Delco TCV connected to the Turbo and WG. The other port is just venting. Any issues with that should be good right?
#20 lookforjoe
lookforjoe
  • 8,311 posts
Posted 09 September 2011 - 04:56 PM
Should be fine - my APexi solenoid is configured this way, and I have no problems (unmetered air, etc..)
