142s Engine Timing
5 replies to this topic
#1 NZRED850R
NZRED850R
  • 56 posts
  • Interests:Cars,Quads,
Posted 11 September 2011 - 04:25 AM
Hi I just had a go at getting my 142 going and seems the timing is out ???
It is a b18 block with a b20 injected head on it, It runs but back fires through the carbs
the green book say to put the distributor in the hole and turn the shaft a little and will slip in then start the car and if it doesn't turn the distributor untill it does the put on the timing light and set ???
Is there some where i can get static timing info and distributor placement
thanks
Bruce
1999 V70 AWD
1969 142S (project)
1995 850 T5R
1996 850R AT, ARD green tune,ARD light weight pulley, Forge CBV, Ipd reverse intercooler piping,IPD HD TCV,Snabb intake and manifold spacer,K&N air filter,16t turbo,MSD blaster coil,,302mm Brakes
#2 gdizzle
  • 19,804 posts
Posted 12 September 2011 - 02:08 PM
Best bet is to ask on turbobricks.com or brickboard.com
550
    someone please talk to me
  • 10,266 posts
  • Interests:My two cars
Posted 14 September 2011 - 02:43 AM
Have you hit it with a timing light as it is? You should get a decent one with a dial indicator so you can tell where the timing is.
Not sure if your 142 is that same as the 242 or not, but you have to pull the vac line off the vac advance pod on the distributor. And then you can check the base timing. It should be in the green books, I think.
#4 DVolvoguy850T5
DVolvoguy850T5
  • 338 posts
Posted 20 November 2011 - 04:38 PM
You need to ensure the off set key is lined up correctly with the oil pump drive shaft. This alignment is imperative to setting up the timing correctly.
The old Climer manual is the best book to use to get this accomplished. Also insure the timing marks on the crank and camshaft are aligned up and all should be ok.
I have a 97 855T5 now, have had 6 other Volvos in the past. Sux I aint got um any more!
#5 brick-a-brac
brick-a-brac
    Old Man Crew Librarian
  • 1,079 posts
  • Interests:I'll show you the life of the mind
Posted 27 December 2011 - 04:38 PM
It doesn't hurt to make certain the distributor isn't off 180 degrees, as it will also drop in at that point as well. Check to see if the rotor is pointing to number one when you're at TDC. Once that's established, timing should be set around 10 to 15 degrees before TDC, if I remember correctly.
1972 142E
1998 V70 T5M
#6 ThePOWERtoRULE
ThePOWERtoRULE
  • 74 posts
  • Interests:All kinds of stuff.
  • Crew:SCC
Posted 29 December 2011 - 04:42 AM
I think you're barking up the wrong tree, honestly. If it runs, when does it backfire through carb? Under load?
What kind of carb do you have?
Check for vacuum leaks as well.
If it runs then you should be close enough to time it with a timing light. If not, then we're looking at another issue.
Only one Volvo left... 1969 142s
