850 Rear Deck Speaker Help?
speaker deck rear
5 replies to this topic
#1 Skyshadow
Skyshadow
  • 51 posts
  • Interests:Just look at it!
Posted 11 September 2011 - 11:58 PM
I'm trying to swap out the rear deck speakers on my brothers 850 but 6x9s dont fit at all. ive heard of lots of people having issues with these deck speakers can anyone recommend the exact size that fits?
1998 S70 T5m Olive Green
ARD Green Tune
IPD Short Ram Intake
#2 Serge
Serge
    Level 6 Senior Member
  • 10,667 posts
Posted 12 September 2011 - 06:01 AM
5x7 speakers fit in the rear deck.
Serge - 95 850 T5
#3 ozzimark
ozzimark
  • 4,352 posts
Posted 13 September 2011 - 10:24 PM
I went the 8" route, I managed to fit a pair of Peerless SLS woofers with some minor modification. I don't know how different the 850 rear deck is, but I had to cut out the retaining plastic on the bottom of the speaker support, and cut a little notch in the rear deck sheetmetal for the speaker terminals.
#4 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 13 September 2011 - 10:41 PM
6x9 fit you just need spacer ring. 20mm is enough. Then all you have to do is drill mounting holes. Other option is cut the rear deck with shears if you want them flush mounted. Either way its about an hour job all said and done. Keep in mind these are not 4ohm.
#5 ozzimark
ozzimark
  • 4,352 posts
Posted 13 September 2011 - 10:47 PM
Nor are they 2 ohm or 1 ohm :lol: 8 ohms :tup:
#6 '12brotruckmofo
'12brotruckmofo
  • 3,478 posts
Posted 14 September 2011 - 08:27 PM
This is so beyond easy. If you want to go the ghetto route, I made a tutorial on it.
Also tagged with speaker, deck, rear
