Wmi Nozzle
Posted 15 September 2011 - 04:30 AM
recommends 0.5mm nozzle (0.02"), but for the aquamist kit which the pump can do 150+ psi and probably a decent flowrate (2gpm+?????)
I'm considering going with a 0.03" because my pump does about 100psi and only about 1.5gpm. Yes, I can buy more nozzles and switch them out, but I'd rather start closer and not have to do anything, than must.
Posted 15 September 2011 - 11:50 AM
Posted 15 September 2011 - 12:08 PM
Also not sure why you would want to use a larger nozzle (than .5mm) when you are using a lower flow pump - I'd think if anything a smaller nozzle would make more sense to prevent pooling.
Posted 15 September 2011 - 12:13 PM
rbodor3, on 15 September 2011 - 11:50 AM, said:
I use the washer reservoir. I think I fill it about every 2 weeks. I don't run the car super hard though except when I'm working on the tune, which has been a lot lately. Mine is a progressive system that starts spraying at 5psi and is all in at 15psi, so your consumption may be different.
Posted 15 September 2011 - 12:41 PM
here's my reservoir
Edited by sconeman, 15 September 2011 - 12:46 PM.
850 Project
SHORT SHIFT KITS---------- TURBO INTAKES---------- SHIFTER CABLE BUSHINGS
Posted 15 September 2011 - 12:42 PM
13.7 @ 99 Automagic
13.8 @ 104 Manual
1995 855M - Quaife, 18T, ARD Blue, Meth, 3" catless, FMIC, N/A(cams & TB), Scone, H&R, Bilstein
Posted 15 September 2011 - 02:13 PM
FOR SALE: Used 75k Miles OEM 16T Turbo/Angled/Ipd HD CBV - PM ME
Posted 15 September 2011 - 03:16 PM
You may have already mentioned this elsewhere, but what does your system use to manage progressive feed? Does it use inj duty cycle/ ign pulse? Mine is straight on/off based on pressure, maybe I need to reconsider that.
Posted 15 September 2011 - 03:40 PM
850 Project
Posted 15 September 2011 - 06:28 PM
Install a "T" in the vacuum line to the boost gauge and run a line to the controller. Knob on the left is adjustable for starting the mist. Knob on the right is adjustable for full spray.....
Posted 16 September 2011 - 12:42 AM
Posted 16 September 2011 - 03:08 AM
rbodor3, on 16 September 2011 - 12:42 AM, said:
I had a Shurflo pump rated for 120psi. I was lucky if I actually saw 80psi under use. Standards pumps also don't have the recirc valve to prevent 'stutter' in the line....
Posted 16 September 2011 - 12:36 PM
That is what I have too...just not completely installed yet...waiting on air pump removal for tank and pump installation. My only beef is that the wires and vac nipple must come out the side...they should have made it so you could surface mount it cleanly without modification.
I like your location choice...I hadn't considered putting it there.
#14
Posted 16 September 2011 - 02:17 PM
I agree. The design of the controller really makes it hard to have a clean install. While I like the Devilsown system, the reviews were good and the price was right, if I did it over again I'd probably go a different route. I'm afraid to run a very aggressive tune, because the system has NO failsafes at all. If my tune was right on the edge and the system failed for some reason, I'd be in trouble. So I keep things conservative just in case. I'm wondering if I could possibly install some type of flow sensor in the line to the nozzle that would alert me in case of a failure?
#15
Posted 16 September 2011 - 02:35 PM
#16
Posted 16 September 2011 - 04:25 PM
CoolingMist has this sensor/flow detector:
#17
Posted 16 September 2011 - 04:32 PM
Volvospeed On Google+
#18
Posted 16 September 2011 - 04:49 PM
lookforjoe, on 16 September 2011 - 04:25 PM, said:
Thanks Hussein! Seems like what I need.
Che, on 16 September 2011 - 04:32 PM, said:
I've been playing with turbo-tuner. Right now I'm running 50/50 water/meth. Are you saying to run a higher percentage of meth? Why as little water as possible?
#19
Posted 16 September 2011 - 04:52 PM
Run no methanol unless its winter. As for water you only want enough to supress detonation. If you are not getting any at your current timing/boost/load back off until you get a hair then add back say 10% for for safety.
#20
Posted 16 September 2011 - 05:04 PM
I did a pull with and without WMI to compare. I could try backing off the meth/water a little, but it seems to be doing its job....
http://volvospeed.co...73#entry2006369
Post 172 shows the logs with and without WMI
