Lighting Mod/ Led Bulbs Over The License Plate?
10 replies to this topic
#1 Mr. Detail
Mr. Detail
  • 108 posts
Posted 17 September 2011 - 03:13 PM
I saw these small LED bulbs on Ebay and wondered if they will screw up anything
with my S70. They supposedly don't overheat but they may trip a code or something.
Has anyone ever used these on their Volvo?
(194/168 SMD bulbs use high intensity 1W LED)
http://cgi.ebay.com/...84c69#vi-ilComp
#2 crazykn
crazykn
  • 1,472 posts
Posted 17 September 2011 - 03:31 PM
Unlike the 850 series, the x70 bulb is not aimed directly downward towards the license plate. Instead it is aimed down at a 45 degree angle, supposedly to take advantage of the bulb's filament placement. For a LED Bulb, you'll need a 5 sided one (four sides plus the top) to evenly light the license plate. It also does not trigger the bulb out warning light.
1998 Volvo S70 T5 Red AT - Stage Zero completed, ARD Orange Tune, ARD Lightweight Crank Pulley. iPd HD endlinks, CJ's Strut brace, iPd Anti-Sway bars, Bilstein TC struts, AC Delco TCV Valve, iPd stainless steel braided brake hoses, StylinMotors silicone vacuum hoses and intercooler hoses, SC-901 w/ Center channel and prologic processor, Planet Audio 400W 4ch Amp, Blitzsafe AUX in adapter, Homelink Visor, rear armrest cupholders, LED sidemarkers, rear mudflaps, and the list goes on and on...
2007 Volvo S80 V8 Silver - Stock.
#3 Mr. Detail
Mr. Detail
  • 108 posts
Posted 17 September 2011 - 08:20 PM
crazykn,
Are you saying that the bulb listed above is not 5 sided? How can you tell? Do you have any suggestion for a place to buy 5 sided bulbs?
I noticed that you have LED side marker lamps on your '98 S70. May I ask where you bought them?
#4 DVolvoguy850T5
DVolvoguy850T5
  • 338 posts
Posted 17 September 2011 - 08:51 PM
Please use V-LED or just copy and paste the link:
http://www.v-leds.co...D-p9722412.html
I purchased these bulbs and have not been unhappy. Some where in our fantastic site is a thread about this. Was told these guys would dim with in 6 months of install. However mine are going strong for over a year. I am not unhappy. For 10 bucks + the shipping? Great deal/value.
There are many many types of LED replacement bulbs. Just make sure it is a direct fit for bulb# 194.
I have a 97 855T5 now, have had 6 other Volvos in the past. Sux I aint got um any more!
#5 Mr. Detail
Mr. Detail
  • 108 posts
Posted 19 September 2011 - 01:53 AM
Thank you DVolvoguy850T5;
and these won't trip the "bulb out" warning idiot light on the dash right?
#6 lookforjoe
lookforjoe
  • 8,311 posts
  • Interests:Making Stuff
Posted 19 September 2011 - 02:29 AM
Another thread that doesn't belong..... :D
#7 '12brotruckmofo
'12brotruckmofo
  • 3,478 posts
Posted 19 September 2011 - 05:04 AM
They may screw up the PERFORMANCE of your vehicle, if you know what I mean.
#8 Mr. Detail
Mr. Detail
  • 108 posts
Posted 19 September 2011 - 11:18 AM
Sorry guys to screw up your "PERFORMANCE" category for you. Where do you suggest it goes for the future??
#9 ccol6975
ccol6975
  • 3 posts
Posted 19 September 2011 - 01:31 PM
It should have been in the cosmetic/detailing section. There is also a pin up there of everything LED.
"98" GLT 230K-- 2.3 SWAP, 16T, WHITES, T5ECU, OBX EXHAUST, SNABB SPACER/IAC, IPD INTAKE/UPPER MOUNT/LOWER MOUNT/WIRES/MSD/HD TCV, N/A INTAKE/THROTTLE BODY/960 PLATE, AUTOMETER BOOST GAUGE
#10 carriedolt
carriedolt
  • 1 posts
Posted 20 January 2012 - 07:07 AM
I was using this led bulbs in my house. But i haven't used this in cars or trucks. I heard that 5 sided led bulb is good. Mostly used in cars for more brightness. So you can go for 5 sided led bulb.
#11 volvos70turbo99
volvos70turbo99
    Mrs. Brightside
  • 212 posts
  • Gender:Not Telling
Posted 20 January 2012 - 08:30 AM
do they come with that girl, screw the bulbs.
1998 s70 glt t5 converted - 16t, white injectors, nxs mbc @ 14psi, k&n drop in filter, high flow cat, full 3in. exhaust, dp, hd wg, na tb, ipd turbo hoses, ard orange tune, stage 0 complete
