Watch Out For Over Crimped Heater Core Hoses...
4 replies to this topic
#1 confused_al
confused_al
  • 146 posts
Posted 21 September 2011 - 01:10 AM
In case you are buying or just bought a blue box Volvo lower/outlet heater hose for any 94-97 850 turbo, S/V/C 70 turbo 98-99. (p/n 9186847), you might want check to make sure the hose is not over crimped.Attached File  HeaterCore hose.jpg   1.02MB   66 downloads
The top hose is the over crimped one and will fail in a month or two, I had three failed hoses in 5 months, all leaking due to the manufacture's over crimping!
The bottom one is the corrected version according to my parts guy.
96 Platinum Wagon
06 V70
95 850 GLT (RIP)
#2 jdlc
jdlc
  • 1,510 posts
Posted 21 September 2011 - 01:45 AM
or diy it using readily available in parts store 5/8" heater hose and save some moolah for mods : )
* SOLD - Joy.D - 98 S70 T5M Blk/Blk, B&G springs/Bilstein HD/TC, ipd TCV, 17psi ST tune, Volans, est short shifter, Forge BOV, SAMCO ic hoses, R-mani, 3" dp/obx exhaust, SAS delete
#3 the commissar!
the commissar!
  • 2,024 posts
  • Interests:interesting things...varies with temperature and altitude
  • Crew:ECC
Posted 21 September 2011 - 05:40 PM
Thanks for the heads up...
JDLC, I did mine in blue FTW! Thanks for the tips...
1998 V70 T-5 -Auto / Pewter - Turbo-Tuner,18T, HD TCVw/ Hallman Pro MBC, custom 3" DP w/ Volvo 2.75" sport catback - both wrapped and coated, RIP, IPD aluminum intercooler, intake w/ K&N cone, R ex. manifold, , gasket matched & polished intake manifold w/ thermoblock spacer, n/a TB w/ 960 plate, Optima bluetop, MSD 6aD and blaster coil, IPD plug wires, IPD poly bushing, Koni FSD w/ Eibach springs, IPD sways 25mm x 25 mm, blue silicone vac, silicone coolant lines, custom intake tubes grill to turbo, skid plate, front lower brace, cherry turbo strut brace, HD endlinks, 302mm brakes, Zeitronix wide-band/data-logger, Walbro w/variable fpr. In process: Home grown HD Endlinks, Meth/H2O injection, greens, catch can, fully built 2.3.
Posted ImagePosted Image
#4 Ihatespeedbumps
Ihatespeedbumps
    The Pied Piper
  • 3,479 posts
  • Gender:Not Telling
Posted 21 September 2011 - 05:43 PM
Just had one of these fail here in the shop as well, thanks for giving everybody the heads up.
98 S70 T5M
#5 BlackT5
BlackT5
    NWC Rod Bender
  • 5,769 posts
Posted 21 September 2011 - 07:09 PM
Good info! Thanks
1998 S70 T5M
