Thinking Of Buying New Struts/springs
850r struts springs fsd ipd springs eibach springs
24 replies to this topic
#1 goobernoodles
goobernoodles
  • 205 posts
Posted 22 September 2011 - 06:34 PM
I've owned a '96 854R with 166k for about 4 months now. Everything on the car is stock except the IPD sway bar end-links I installed a couple days ago. I plan on getting a IPD sway bar kit in the near future. Prior to that though, considering the car has 166K on it, I'd like to "freshen up" the ride with new struts/shocks and springs. I'm looking for better performance/less body roll/movement and a moderate drop. I'd like to avoid having a harsh ride.
I'm thinking a Koni FSD kit paired with either Eibach or IPD springs. Does anyone run either combination? Pictures would be appreciated.
Red 1996 854R / 18T / ARD Blue / M4.4 / Koni FSD / IPD Springs / HD End Links / EST Strut Brace / OBX Turboback / ARD Crank Pulley
#2 trs80
trs80
  • 563 posts
Posted 22 September 2011 - 06:49 PM
inb4toldtosearchpost
I believe the most common setup is IPD springs and Koni Sport shocks/struts. I have no experience with the FSD units so I can not attest to their awesomeness. You may want to replace the spring seats and other misc. front-end components to better compliment the new setup. Im sure others with the setup are looking at will chime in as well.
'05 S60R, DD.
'97 850R, Mods in Garage: Volvo 850 R (1997)
'96 Jeep Cherokee. Sold to a friend.
#3 Mesoam
  • 19,745 posts
Posted 22 September 2011 - 06:53 PM
Are you sure the dampeners have never been replaced? 166k is pretty high mileage on stockers...
#4 scandalo
scandalo
  • 1,764 posts
Posted 22 September 2011 - 06:58 PM
Yellows + H&R on 235/40/18s.
Shocks aren't really going to play into drop. I have heard good things about the FSDs and would consider them over the yellows if I had to do it again.
if people are hating, your doing it right
Stu M. or Stum
98 S70 2.3 stgIII
#5 goobernoodles
goobernoodles
  • 205 posts
Posted 22 September 2011 - 11:06 PM
Well, I ended up placing an order with IPD for a Koni FSD kit, IPD springs, XC90 spring seats, and a few other things. I'll post some pictures afterwards.
#6 trs80
trs80
  • 563 posts
Posted 23 September 2011 - 01:18 AM
Congrats. Im sure you will enjoy that setup.
'05 S60R, DD.
#7 Tommy.
Tommy.
  • 5,729 posts
Posted 23 September 2011 - 02:55 AM
Have fun with the ipd's rubbing on the bump stop washer.
#8 Volvo5.0
Volvo5.0
  • 1,106 posts
Posted 23 September 2011 - 01:16 PM
I have the FSD shocks with Eibach springs. I love the ride, but the Eibachs didn't lower the car much. For me it worked out well since the roads in the DC area suck. If you are looking to lower your car, you probably made a better choice with the IPD springs....
1998 S70T5M, 2000 Built B5244T2 RN Engine, K24 turbo, 550cc injectors, Turbo-Tuner, Coolingmist Progressive WMI, Precision FMIC, 311whp 363wtrq
#9 Ex850R
Ex850R
  • 125 posts
Posted 23 September 2011 - 02:04 PM
I am swapping a lot of my good gear off my S70T5 onto my 'new' V70T ( GLT for you guys i think ) and the ONE thing that isnt going in is the IPD springs.......
I know i am getting old , but , they shook and banged the stuff out of me and my loose dashboard in the T5 , oh yeah they dropped the stance and it looked cool , but not worth the noise and lack of comfort.....
I have my moved the koni adjustable fronts and rear bilsteins into the GLT with stock old springs and i gotta say it handles well too , none of the noise either , and ohh , bloody comfortable !!!
I will be selling those demon springs asap!
Good luck there !
L.
1998 V70T . 1978 245DL Wagon . EX - 1996 855R Manual Wagon ( the one in my SIG , hit that front side by damn gorgeous youn Girl and scrapped....)
#10 goobernoodles
goobernoodles
  • 205 posts
Posted 23 September 2011 - 02:57 PM
My dash is pretty loose too... I'll see how it goes.
#11 trs80
trs80
  • 563 posts
Posted 23 September 2011 - 04:28 PM
The dash is easy to take out of the car. The common places for dash cracks are around the glove box and the support mounts. My dash is in such bad shape I pulled a complete unit from the junk yard and will be swapping it in soon.
'05 S60R, DD.
#12 Boxman
Boxman
  • 125 posts
Posted 23 September 2011 - 09:22 PM
AFAIK the bumpy ride is caused by sporty shocks, not springs. Springs are usually not bothered by small deflections, they are for the large bumps.
Koni FSD is just the compromise; soft on bumpy roads and sporty in the corners (because of the spring loaded valves that open at frequencies >10Hz).
Anyway, I'm busy dropping Koni FSD's + Eibach springs on my ride this weekend. I'll let you know how it rides :)
#13 goobernoodles
goobernoodles
  • 205 posts
Posted 23 September 2011 - 11:38 PM
That's why I grabbed em. I'll be interested in hearing your early impressions.
#14 Ex850R
Ex850R
  • 125 posts
Posted 24 September 2011 - 12:12 AM
The springs are lower than stock , taking out the 'comfort' part that is the extra length on a STD spring , the lowered spring also reduces the length of the damper piston action so you loose that compliance also.
My Koni's / Bilsteins in my GLT with STD springs give a really nice ride compared to the VERY harsh and unforgiving ride the IPDs give , by the way this is both cars running 16" wheels with good quality tyres...
Give it a go , if you have bad roads , you can always put up with it or change back easily if you do it yourself its cheap!
I ran my 855R wagon with 17" wheels and its standard low sport suspension ( with the koni's and Nivomat rear ) and sometimes it was really annoying ! But on a good road on boost YEAH !!!
I must have a look at those 855R springs against the IPD ones , see how they differ , i will post my results !
All i can say is , go with what you want to do and suck it and see , its all about the fun you have trying stuff to make your ride what YOU want !!
L/
#15 Ex850R
Ex850R
  • 125 posts
Posted 24 September 2011 - 12:21 AM
There is a repair thread on here about the dash tabs being fixed with aluminium strips , that will stop it happening again if you strengthen the replacement one before you put it in....
This job is on my list now i have the two cars at home and so i can sell the S70T5 without the rattles !
I wish it were so "easy" i have soooo much stuff to do it is scary sometimes..........
Get onto strengthening that replacement one up before it goes in , a bit of expander foam for sound deadening could be the go too ??
L.
Nice looking car ! I wish my S70T5 was so shiny ! Dark alloys look best too , i never got to do that.....
Are they 17" Volans ? Just like my old R ?
L.
#16 Boxman
Boxman
  • 125 posts
Posted 24 September 2011 - 03:46 PM
It's been a long hard day, but I've got them on.
Car wasn't lowered that much with the 30mm lowering springs, as far as i can see, not at all! But I was coming from nivomats and possibly the option sports pack, so the drop could be just 1mm.
The rear spring disks at the bottom are a major pain in the ALL GLORY TO THE HYPNOTOAD. Just a heads up. The nut is rusted on and the bolt is not actually connected to the disk, so can spin freely. I used a crowbar to exert some extra pressure, then jacked it up when I had it loose for a few mm so I could grab the bolt-head. Cost me about an hour, two simple bolts.
Anyway;
THE DRIVE IS AWESOME! I didn't really give in any comfort at all (maybe they're even more comfortable) and it really does handle like a mad car. Didn't know tanks could be this agile. Doesn't really hang over in the corners anymore. I do still need to get it aligned though. But you will like it, i'm sure.
#17 goobernoodles
goobernoodles
  • 205 posts
Posted 28 September 2011 - 09:47 PM
Anyway;
Cool, thanks.
I got the parts on Monday, can't wait to toss them on the car on Saturday. I'm gonna put the car on stands on Friday and hit the bolts with Aero Kroil. I was told it's better than PB blaster... guess we'll see.
#18 Meek
Meek
  • 572 posts
Posted 28 September 2011 - 11:13 PM
XC90 spring seats? Please elaborate as I have to redo my suspension soon too...
96 855R
00 Viggen
#19 trs80
trs80
  • 563 posts
Posted 29 September 2011 - 01:14 PM
They are considered Heavy Duty, some what similar to iPD's HD spring seats. They are a newer OE design that is supposed to be less prone to fatigue.
'05 S60R, DD.
#20 rmorse
rmorse
    All my sperm swims to the right
  • 1,590 posts
Posted 29 September 2011 - 02:41 PM
Kinda going a bit off topic here, but one of you guys mentioned going from nivomats to normal. All I need to do that is my ipd blue springs, koni yellow rear shocks, and a new strut mount, right?
