Plastidip + Krylon Wheels
peel off temporary wheel color painting rims ronal r38 krylon plastidip
58 replies to this topic
#1 devolv
devolv
  • 452 posts
  • Crew:ECC
Posted 28 September 2011 - 01:56 PM
I picked up a set of wheels for a Jaguar XF with a full set of winter tires for $400, the set was with 245/45/18 Pirelli Sottozero with barely any use. So I got them dismounted, sold the tires for $450 and paid my tire guy $40 for the dismount. It also came with Jag TPMS, but 2 were damaged. 2 others were still good bit not sure how much they are worth.
5x108 with 76mm center bore 18"x8 Ronal R38s ET 42 in 2 tone silver with machined edge. Has a but of rash but I'll be sanding those out. More pics later when mounted, but I think I did pretty well for myself!
So here are the pics of the wheels dismounted and cleaned up a bit and hand dryed. Had quite a bit of brake dust residue which was a oh yeah! to clean.
Since I got these wheels for nothing, wanted to make them pop a little more for money next to nothing. PlastiDip to the color I want to match my car:
First coat:
Second coat:
And third coat:
Top Coat of: Paint: Krylon Fusion Textured Shimmer Metallic Black <- does not look black at all though. More like Dark Grey Metallic
Light Coat:
Peeling off the machined edge: Using a exacto knife to cut the edges before peeling as it'll lift the other parts if you don't.
Finished Product:
Just to clarify. PlastiDipping wheels are a temporary solution, they will eventually wear down during long term use (and I mean a 2-3 years maybe). But they are a great solution to wheels that you don't want to damage from it's stock appearance, and to test out different colors on them without the commitment. Plastidip is also very easy to work with, and lays on very evenly without much technique. You will need at least 3-4 coats, as you need the build up enough plastidip so that it can peel off.
97 850 GLT LPT 16T - EST Intake - EST Strut - Ferrita Exhaust - KW Coilovers - Undergoing S70/V70R front end retro fit ;)
04 S60 R - 6 MT - Titanium Grey - Nordcap - Sport Kit - Painted Trims - BBS CK 19x8 - CFW CF VST Front Lip - AEM Dryflow Intake - CFW PCC Spoiler - CFW CF Roof Spoiler - Clear headlights + 05+ Custom LED Tails - Eibach Springs - UltraRacing Strut Bar - Autovation Pedals - TWM Short Shifter + M1 Abrams Knob - 05+ Center Console
#2 noodle
noodle
  • 236 posts
Posted 28 September 2011 - 02:08 PM
Nice dude I always wondered if that'd work, bout to try that on my winter wheels
#3 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 28 September 2011 - 02:12 PM
Looks good. I would have masked it off or used PVA though. If they last a year I will be amazed, but it is a good idea for trying out different colors :tup::
#4 boxpin
boxpin
  • 835 posts
Posted 28 September 2011 - 03:05 PM
I still love your car. Oh, rims look good btw.
13.7 @ 99 Automagic Posted Image 13.8 @ 104 Manual
1995 855M - Quaife, 18T, ARD Blue, Meth, 3" catless, FMIC, N/A(cams & TB), Scone, H&R, Bilstein
#5 Serge
Serge
    Level 6 Senior Member
  • 10,667 posts
Posted 28 September 2011 - 06:50 PM
That is a fantastic idea. It's like color skins for your wheels. Good work.
Serge - 95 850 T5
#6 Aequitas_Veritas
Aequitas_Veritas
    Blue Calipers&Balls
  • 7,693 posts
Posted 28 September 2011 - 06:57 PM
Are these your winter wheels?
Cause even though they look pretty damn good, your old wheels are much sexier.
40+ mods and counting...
#7 devolv
devolv
  • 452 posts
  • Crew:ECC
Posted 28 September 2011 - 07:04 PM
Yep, winter, perfect test to see if Plastidipped finish would hold up.
#8 mega moose
mega moose
  • 227 posts
  • Interests:lotsa stuff
Posted 28 September 2011 - 07:08 PM
wheels look good man, I was looking into jag wheels for a while myself.
derp.
#9 devolv
devolv
  • 452 posts
  • Crew:ECC
Problem with masking off is that the Plastidip will still be sprayed on the mask, and that coating is enough to "connect" with the parts you're not masking. So once you peel off, you'll still need a knife to separate the 2 surfaces from the bond.
#10 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 28 September 2011 - 07:09 PM
Thats why leading edge gets a couple layers that you tear away between coats.
#11 adamjjohn203
adamjjohn203
    Steve
  • 1,960 posts
Posted 28 September 2011 - 07:12 PM
Looks good and gives you a good idea of what they'd look like.....but I had plastidip on my roof rack fairing and the sprayer at the wash bay took that off pretty easily. Especially if you don't prep the existing paint on the wheels.
#12 devolv
devolv
  • 452 posts
  • Crew:ECC
Posted 28 September 2011 - 07:26 PM
True, but given the detail complexity of applying such a mask. I'd rather just do it this way, it'll take a long enough time to mask all the edges just for one mask layer. Under your suggestion, it'll take some a good hour or so just to even start spraying. Which is why I decided to go with the peeling method, which is the beauty of Plastidip, I have a steady hand and a good eye so this to me is no problem. But of course, it may be worthwhile for someone else to take on your suggestion.
I guess it depends on what you're trying to spray it on, and the amount of coats you put on it. For wheels, as long as they are clean wax-free and the surface is smooth, I think Plastidip sticks on a bit better. So rusty old wheels or severely oxidized surfaces would be not a good solution.
#13 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 28 September 2011 - 07:37 PM
#14 Logan2224
Logan2224
  • 1,124 posts
Posted 29 September 2011 - 03:32 AM
Woah! Somebody on volvospeed who isn't mentally challenged painted their wheels!
Seriously though, looks really good I love it.
02 C70 Coupe - 92k, Silver/silver, 6000K HIDs, EST intake, IPD HD TCV
#15 EVL WAGN
EVL WAGN
    Old Man Crew Trailer Park Supervisor
  • 4,505 posts
  • Interests:Golf, Hockey, and Snowboarding!
Posted 29 September 2011 - 04:06 AM
Looks awesome dude...I liked it better as one colour though myself.
Amish Approved!!!
#16 Swag Swag
Swag Swag
    Captain Tow Hook
  • PipPipPipPip
  • 4,478 posts
  • Crew:SWC
I used that exact same krylon spray paint on my pegs about a year ago, it holds up extremely well. I wish I would have plastidipped first cause getting it off my pegs was a huge PITA haha. Wheels look good though!! Way to do something different
Spence—855 T5-R W/RN Swap—NWC
http://www.seshday.com/invite/?r=43707
#17 -Matt01
-Matt01
  • 412 posts
Posted 29 September 2011 - 05:20 AM
i hate to say it but with the chrome lip they look like RTX... and they have no place on a volvo.
Quote
Same with the AWD... if you don't actually own one, or never have, or plan to do so, then shut your pie hole.
#18 devolv
devolv
  • 452 posts
  • Crew:ECC
Posted 29 September 2011 - 11:42 AM
Yeah I was thinking the same thing. Fortunately I'll be easy to do if I wanted a single color.
It's not chrome, it's a machined lip. Secondly i modeled it to this:
#19 RobT5.
RobT5.
    Doctor Retardapus
  • 3,093 posts
  • Interests:We-mons
    Orange Soda
    Speeding
    Archery
    Cars
    Poking
    Your Mom
Posted 29 September 2011 - 12:03 PM
O.o ummmmmm how long do you expect this to last? 1 month max?
+1 for effort
+1 for the idea
-1 if you think its going to last very long.
+1 because they came out looking good.
edit.
:lol: at least you didnt get drunk and paint them blue.
Edited by RobT5A, 29 September 2011 - 12:08 PM.
1998, S70 T5.
RobT5 FloridaVolvoCommunity Car Domain
Quote
optimus prime when i do get this whole project underway im totally gonna eat a sandwich in my engine bay
#20 devolv
devolv
  • 452 posts
  • Crew:ECC
Posted 29 September 2011 - 01:10 PM
+1 for effort
+1 for the idea
edit.
-1 for doubting it. I think PlastiDipping wheels have been done before, and it definitely lasts more than a month.
Honestly, this is more an experiment for me, I want to know that answer as well. So someone has gotta try it. I think with PlastiDip alone, it may last a bit less longer with contaminants and other elements(brake dust, dirt, oil) may break it down or stain them sooner, but with the paint on top, it may add another layer or durability to it. Who knows.
If this lasts an entire winter season, then I would be happy. Yes, these will be my winter beaters. If it doesn't, I won't complain. For both money and effort for the color change, I would still do it again. I mean Plastidip for you guys in the states is $5-7 a can, and this although many coats you can have them finished in 2-3 hours, so it's not a lot of effort.
