The mechanic says it blows smoke after coming to a stop because the turbo seals need changed.Ever hear of this problem or what it costs to fix it?Thanks
!989 740 Turbo Seals Leak
Started by eggman5480, Oct 03 2011 04:06 PM
Posted 03 October 2011 - 04:06 PM
#2 Guest_FAAguy_*
Posted 04 October 2011 - 02:29 PM
If it only blows smoke while idling (and only after the car warms up) and not when under accel., then it is your turbo. I just changed the core in mine (which was about 8 years ago, and I think it costed me ~ $400). I bought it from turbonetics.
Posted 25 October 2011 - 06:27 PM
It's possible that the turbo oil return pipe is partially blocked by coke, where this may prevent some of the oil returning to the sump. If this is the cause and it's corrected (usually replacing the pipe) soon enough, odds are the turbo will be fine.
You might also want to be sure that your crankcase ventilation is in good order: http://www.brickboar...tion_A_Treatise
