Auto Trans Not Downshifting
#1 NYrobbie77
NYrobbie77
  • 15 posts
Posted 05 October 2011 - 01:03 AM
Hey all. I have a 98 v70 fwd auto with just under 200k miles. Since I bought it last year it has always shifted hard into 3rd, a bit smoother with light throttle. I did a partial drain and fill last month as the trans fluid was black as 3day old coffee. It did not smell burnt or anything
Last few days after a 20 min hwy drive, when slowing down it feels like it stays in either 4th or 3rd gear like if u didn't downshift or push the clutch in, and then finally downshifts and is smooth braking again.
I have no cel or flashing shift light. Does this sound like the trans is getting ready to die or something else?
Thanks in advance.
'98 V70 GLT FWD auto - 192k+ miles - bone stock
#2 Flukey
Flukey
  • 340 posts
  • Interests:fly fishing, offshore fishing, cars, baseball-PHILLIES, beer drinking, and poontang.
Posted 05 October 2011 - 09:11 AM
Most likely the torque converter clutch is staying applied. The lock-up solenoid is probably clogged. Try a complete flush and add a bottle of Lube Guard
that is in the red bottle. Its worth a try.
#3 NYrobbie77
NYrobbie77
  • 15 posts
Posted 05 October 2011 - 01:58 PM
Yah I was thinking possibly stuck TCC too. Am reluctant to do a total flush as the fluid was so old and bad. I did try hitting the brake once I was in TCC lockup and it did unlock right away. Will try another drain and full.
#4 NYrobbie77
NYrobbie77
  • 15 posts
Posted 22 January 2012 - 03:13 PM
just wanted to give an update. the problem was fairly intermit then all of a sudden started getting stalling issues, CEL P0120 and after a couple weeks P0123 and getting very erratic shifts, flashing upshift light and lights on shifter. if i let go of the throttle while cruising the trans would downshift violently, also would have late upshifts, once wouldn't go into TCC lockup.
i replaced the throttle position sensor and everything has been cleared up. no more CEL, shifts correctly, even seems to have gotten rid of the harsh upshift into 3rd gear that i always had. its been 2 weeks since i replaced the sensor and no more troubles.
