Best Place To Tap Into The 12v For Amp / Sub?
Posted 12 October 2011 - 12:56 AM
Tried searching, but posts only talked about the audio signals, not the power.
Where is the best place to tap into the 12V for amp / sub?
Or do I have to route the wires directly from the battery? If so, how did you guys route the wires?
Thanks in advance!
Jae
1998 S70, SC-900 HU.
Past: '05 S60R // '98 C70 T5M // '95 BMW M3 // '94 855
Posted 12 October 2011 - 01:00 AM
Posted 12 October 2011 - 01:11 AM
What amp and how much power you plan to draw? Anythying over call it 150w and you will need to run new wires. As for pass through, there are write ups on both left and ride side pass throughts. Right side is best for any wire heavier than 1ga. Left is fine for everything else.
Volvospeed On Google+
Posted 12 October 2011 - 01:31 AM
'05 xc/90. The stereo sucks.
Posted 12 October 2011 - 01:34 AM
Posted 12 October 2011 - 01:43 AM
for any sub amp should always come from the battery.
And don't forget a fuse for that cable AT the battery.
Burning Volvos smell awful...
Posted 12 October 2011 - 01:56 AM
Posted 12 October 2011 - 01:59 AM
Posted 13 October 2011 - 04:18 AM
Posted 13 October 2011 - 11:55 AM
Repairs and replacements: strut mounts, spring seat,pcv,timing belt,power steering pump,sas delete,ectx2.
Tommy., on 14 May 2012 - 11:28 PM, said:
Posted 14 October 2011 - 02:19 AM
I would never ever ever run anything less than 8awg....did I mention EVER? And don't cheap out with a crimp together ATC fuse holder either...spend a few extra bucks and run an AGU holder.
Amish Approved!!!
Posted 14 October 2011 - 05:49 AM
#14
Posted 14 October 2011 - 07:01 AM
Volvoboi24, on 14 October 2011 - 05:49 AM, said:
You only need the remote wire if you are using RCA or someone other line leval out. Speaker/power level outs do not need the trigger wire.
#15
Posted 14 October 2011 - 08:31 AM
