Engine Bay Cosmetic Or Performance Accessories? Also Other Ideas For External?
s70 t5 glt 1998-2000 v70
22 replies to this topic
#1 the most modern GLT
the most modern GLT
  • 63 posts
Posted 18 October 2011 - 01:23 AM
right now i have a 1998 s70 GLT. god i love this car. im only 17 so money car sometimes be an issue but i want some ideas of cosmetic things to external, but mostly engine bay since I have ignored that the most. What i have on it know.
INTERNAL:carbon fiber detailing in dash and around shifter, Front lights inside are white LED's, Back inside lights are red LED's, floor lights in front are blue LED's, have jvc KW-AVX740, all aftermarket speakers through out.
EXTERNAL: carbon fiber mudflaps and gas door and lock on trunk and small part of door handle, ABM projector headlight, HID 6000k low beams, HID 5000K high beams, yellow brake calipers, stainless steel painted grill with yellow accents and Volvo moose on it(was tired of high mileage club emblem)
PERFORMANCE: owner before me is huge Volvo freak (in a good way) and has Ferrari's. had it lowered an inch, k and n air filter
PROJECTS: 2 12 inch kenwood subs in custom fiberglass boxes on sides of trunk out of the way in the center, max legal tint, replace headliner(its drooping).
I do all the work myself (except probs tint) i like a black on steel modern look and love yellow accents, i will try to get some pics soon.
Main things i want to tackle are engine bay to look sweet and aggressive( i also like adding power to it).
Exhaust system or tip or what? im curious about exhaust idea's...
any things you have done that look sweet tell me about, but i don't want to just straight copy someones custom ride. Thanks, Noah
the car is black with black leather interior
1998 Volvo S70 GLT- V70R ECU, Snabb High Flow Intake, Snabb Silicone Idle Control, 8mm Kingsborne Wires, OBX Strut Bar, FCP Silicone Inter Cooler Hoses,Silicone Turbo Hoses, ABM Projectors 6000k Low 5000k High
1999 Volvo V70 XC- Rebuilding as we speak...
#2 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,627 posts
Posted 18 October 2011 - 01:29 AM
Paint the valve cover and tuck the wires would be a start.
#3 Black Betty
Black Betty
  • 7,000 posts
Posted 18 October 2011 - 01:30 AM
exhaust: obx is cheap on e.bay
for the engine bay, just go at it with some simple green til its clean and then polish the crap out of anything you see that aluminum. Scone-man's J pipe makes for a nice additional bling
example
member Aequitas Veritas car
#4 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,627 posts
Posted 18 October 2011 - 01:36 AM
http://www.ebay.com/...=item1c1fe98644 <-- offer 300 with make an offer and they take it.
#5 the most modern GLT
the most modern GLT
  • 63 posts
Posted 18 October 2011 - 01:39 AM
Holy stuff beautiful engine bay, is that yours? painting what valve? what is the obx system and what does it do?
#6 RobT5.
RobT5.
    FRED SANFORD
  • 5,029 posts
Posted 18 October 2011 - 01:53 AM
Truth in that right there :)
OBX sells a strut bar, and an exhaust system.
Probably half the people here have both of those. either both, or one or the other.
#7 the most modern GLT
the most modern GLT
  • 63 posts
Posted 18 October 2011 - 01:55 AM
what does the strut bar do?
#8 Fake-R
Fake-R
    Rarest Member Ever
  • 2,170 posts
Posted 18 October 2011 - 02:46 AM
Stiffens the front end. because of the gaping hole in the front of the car called the engine bay. :lol:
R bumpers aren't terribly expensive, and add to the look of the car, more lowering is always good, iPd's springs drop the car 1.75", so almost a full inch lower than where you're at. There are a good amount of things you can do. A good set of wheels always helps too.
-1996 850 Turbo
-2007 XC90 V8
#9 the most modern GLT
the most modern GLT
  • 63 posts
Posted 18 October 2011 - 03:09 AM
im not doing wheels till my Yokohama's wear out but i actually like my rims(the steel alloy ones) did some more research and a ipd strut ball sounds like a good bang for the buck. im reading alot of bad reviews about obx exhaust tho
#10 T5power
T5power
  • 4,929 posts
Posted 18 October 2011 - 03:39 AM
i did a black and gold theme. to go with the wheels and intercooler.
CHECKMATE
#11 the most modern GLT
the most modern GLT
  • 63 posts
Posted 18 October 2011 - 03:49 AM
i see an hid kit as well, did you just use a high heat spray paint or what? the owner before me had after market hoses and piping i could just airbrush it after cleaning bay...
#12 oprahhwinfreyy
oprahhwinfreyy
  • 290 posts
Posted 18 October 2011 - 06:11 PM
T5Power has the right idea. Love his bay
1998 S70 GLT // NeckBrkz //
#13 TaskMule
TaskMule
  • 1,341 posts
Posted 23 October 2011 - 03:13 PM
example
A thing of beauty. :tup:
98 V70R AWD
128k miles, 18T, 3" DP, ABM's, SAS delete, Samco's, K&N panel, white's, 18" Pegs/RE760's
#14 the most modern GLT
the most modern GLT
  • 63 posts
Posted 23 October 2011 - 10:59 PM
so i simple greened my bay and now my 2nd cylinder is misfiring
#15 oprahhwinfreyy
oprahhwinfreyy
  • 290 posts
Posted 23 October 2011 - 11:04 PM
its probably got water in it.
#16 the most modern GLT
the most modern GLT
  • 63 posts
Posted 23 October 2011 - 11:06 PM
in what the alternator? how can i fix? its my daily driver and i need it tomorrow
#17 oprahhwinfreyy
oprahhwinfreyy
  • 290 posts
Posted 23 October 2011 - 11:13 PM
might have something to do with your fuel injectors, since there right there in front of the engine. while cleaning you might have loosened a spark plug,
#18 the most modern GLT
the most modern GLT
  • 63 posts
Posted 23 October 2011 - 11:14 PM
where can i find out how to fix this or can you tell me a bit more.
#19 oprahhwinfreyy
oprahhwinfreyy
  • 290 posts
Posted 23 October 2011 - 11:18 PM
water got in my distributer cap once, and caused some misfires.
an autoparts store can help you fix it. but if you want a diy, check and make sure your spark plugs are completely connected and not loose, or water in your distributer cap, dont know what to do about the injector problem if it is the injectors causing the misfire.
#20 oprahhwinfreyy
oprahhwinfreyy
  • 290 posts
Posted 23 October 2011 - 11:24 PM
more than likely i think theres water on your spark plugs or in the distributer cap
