Reverse Light Diagram S70
s70 glt t5
5 replies to this topic
#1 the most modern GLT
the most modern GLT
  • 63 posts
Posted 21 October 2011 - 07:12 PM
i need the wiring diagram for the rear reverse light i have to get power from it to hook up camera. i have to link power from it to camera and signal from that to stereo.
thanks, Noah...
1998 Volvo S70 GLT- V70R ECU, Snabb High Flow Intake, Snabb Silicone Idle Control, 8mm Kingsborne Wires, OBX Strut Bar, FCP Silicone Inter Cooler Hoses,Silicone Turbo Hoses, ABM Projectors 6000k Low 5000k High
1999 Volvo V70 XC- Rebuilding as we speak...
#2 Dan A
Dan A
    Old Man Crew Pledge Pres.
  • 1,994 posts
Posted 21 October 2011 - 07:21 PM
Easiest is to tap right in to the wire near the light.
99 V70R
98 V70 GLT
#3 the most modern GLT
the most modern GLT
  • 63 posts
Posted 21 October 2011 - 07:26 PM
what wire is positive and negative? color?
#4 the most modern GLT
the most modern GLT
  • 63 posts
Posted 21 October 2011 - 07:40 PM
there are two purple with strip, 2 blue, 2 black and one red. is red negative in this case, weird.
#5 Dan A
Dan A
  • 1,994 posts
Posted 21 October 2011 - 07:57 PM
Red is not negative. I have a wagon so I'm not sure if the color codes are the same but I'll check if I can remember. But I went directly to the bulb housing and checked there with a voltmeter IIRC.
99 V70R
98 V70 GLT
#6 the most modern GLT
the most modern GLT
  • 63 posts
Posted 21 October 2011 - 08:50 PM
so blue was positive reverse... purple was fog light, black was licences plat light, also running im guessing which leaves red as - which powered my camera
