1999 S70 Heater Luke Warm..why?
11 replies to this topic
#1 Socalfem
Socalfem
  • 128 posts
  • Gender:Female
Posted 23 October 2011 - 09:59 AM
My heater doesn't get very hot, wondering why and what I need to check ?
#2 JRL
JRL
  • 329 posts
Posted 23 October 2011 - 11:49 AM
What does the temperature gauge read when the car is warmed up?
If it's not at "3:00" you have a problem.
95% of the time it's a bad/stuck thermostat
This is automobile 101
#3 Socalfem
Socalfem
  • 128 posts
  • Gender:Female
Posted 23 October 2011 - 09:54 PM
It's at 3:00, so no problem there
How do I check to see if thermo stuck ?
#4 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 24 October 2011 - 08:47 PM
Your car warms up so its not that. Have good flow? If so I would check the core.
#5 Double0
Double0
  • 71 posts
Posted 24 October 2011 - 09:06 PM
had the same problem last year, car got to normal temp on gauge heat was just not very hot. Often had foggy windshield glass. Even though it was not leaking, it was my heater core. Took it out old one and it even looked pretty good, no obvious signs of damage other than a bit of hard water stains on some fins.
Put in the new core and have been enjoying the heat ever since.
Its not that hard to do a heater core on a volvo compared to other cars. There are diy's on it.
Black 2000 V70R, Stage 0'ed, and ready to run
#6 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 24 October 2011 - 09:20 PM
Correct. Yours was probably colgged.
#7 Socalfem
Socalfem
  • 128 posts
  • Gender:Female
Posted 24 October 2011 - 09:26 PM
So if it's clogged does it stll need to be replaced?
Do you have a price range for a new heater core?
#8 Double0
Double0
  • 71 posts
Posted 24 October 2011 - 09:43 PM
We tried flushing it from the engine bay at firewall connections but that had no effect on it. Like I said it didn't leak into the car at all, the giveaway was the foggy windows I think.
I think I paid about $250-350 (CND) for the core, but I bought an OEM one from a Volvo dealership, couldn't take the cold anymore and wanted it done.
#9 db130
db130
  • 724 posts
Posted 24 October 2011 - 10:00 PM
http://volvospeed.co...r-core-install/
I've had to replace the heater core in all 3 cars in my signature(most recently this past Saturday on the 217k car).
2000 V70XC SE, 149k '00 R Duals/Angled 15G/15 psi ST T5 tune/Delco TCV/UK 302s/180°F Stant Superstat/Samco hoses/IPD HD CBV/Sconeman intake
1998 S70 T5, 135k '00R 302s/Delco TCV/IPD 3" Turboback(taken off the road)
1998 S70 T5, 223k DIY AEM BCS/IPD Stage 1 ECU
Check out the Delco BCS/TCV
#10 Socalfem
Socalfem
  • 128 posts
  • Gender:Female
Posted 24 October 2011 - 10:11 PM
Thanks guys
Btw I don't have the foggy windows
#11 Redbeard
Redbeard
  • 3 posts
  • Crew:ECC
Posted 21 December 2011 - 08:06 PM
I am having the same problem after replacing the heater core with a new unit.
#12 Box83Brick98
Box83Brick98
  • 103 posts
  • Interests:Cars of all kinds, music, mechanical engineering
Posted 21 December 2011 - 09:19 PM
ME too, my heat just doesn't seem as hot as it did before my new core.
'98 T5M 163k and still kickin. [6000k HID lows and fogs, OBX exhaust, OBX strut brace, MBC @ 12psi, IPD Sport Springs, Billstein TCs]
'83 Chevy Caprice (Lead Sled). 67k original miles, 4 bolt 350 swap.
