Horn Swap Out
Posted 25 October 2011 - 04:30 PM
On my '98 S70 when you open the hood, there are two stock horns with one factory plug going into each.
In the installation booklet that came with the PIAA horns, it says to "Cut off the factory plugs and crimp on an insulated
1/4" female blade connector to each factory positive (+) wire. I really don't like cutting factory harnesses of any kind so
my question, is there any way I can avoid doing this? The plug on the O.E. horns is pretty big.
The PIAA horns have two male terminals coming out of them, one for positive and one for ground.
PIAA included two ground wires in the kit with a female blade on one end and a lug for a grounding screw on the other.
P.S. I can barely see whjat I am doing with that big black plastic cowling in the area. Not sure if it is worth trying to remove that for clearance.
Posted 25 October 2011 - 05:36 PM
Buy new horns from Volvo?
Posted 25 October 2011 - 05:38 PM
40+ mods and counting...
Posted 25 October 2011 - 05:57 PM
bam! not only are they good for delco BCS, they are also good for horn installs.
1998 S70 T5, 135k '00R 302s/Delco TCV/IPD 3" Turboback(taken off the road)
1998 S70 T5, 223k DIY AEM BCS/IPD Stage 1 ECU
Check out the Delco BCS/TCV
Posted 25 October 2011 - 05:58 PM
Posted 29 October 2011 - 06:29 AM
Mr. Detail, on 25 October 2011 - 05:58 PM, said:
1 wire is hot the other is the return. The horns don't reach ground till the horn switch is depressed.
I forget which one is which. I had to tap into one for powering my air horn solenoid.
Posted 06 November 2011 - 01:32 PM
1999 Volvo V70 XC- Rebuilding as we speak...
Posted 06 November 2011 - 03:27 PM
Posted 11 November 2011 - 03:02 PM
This way your horns will be plug and play, and you can then swap factory horns back in whenever you need to.
Posted 15 November 2011 - 01:23 AM
Posted 15 November 2011 - 07:02 AM
Posted 27 November 2011 - 08:59 PM
1993 Mercedes-Benz 190e 2.3 91k still broken
1996 Volvo 855 GLT-R 320+k and going ( Project GLT-R)
1998 Subaru Outback SUS -Daily Driver
Volvo for LIFE......
