240: Fcp Tail Lights With Circuit Cards Burning Out
23 replies to this topic
#1 rodrigo
rodrigo
    Chatroom Scare Crow
  • 7,417 posts
Posted 26 October 2011 - 11:54 AM
My 240 has had this constant issue where the card tail light circuit card is always burning out on the passenger side. I've tried using the card it came with (from FCP) and an OEM card and they both burned out after a few weeks.
What can I do to resolve this other than hardwire the tail lights??
1989 BMW 325i - 1992 Volvo 240 - 1992 Vespa PX200E
1993 Bridgestone RB2 'porteur-plaisir' conversion - 1995 MASI Gran Corsa - 1996 Gunnar Roadie
#2 Three Fat Tigers
Three Fat Tigers
    RWD Moderator
  • 1,746 posts
Posted 27 October 2011 - 05:01 AM
Hard to say as such a short life is not a common issue.  Without all the details I can only speculate that maybe the contacts on the sockets are damaged and allowing the issues to perpetuate.
Might switch to LED lamps where the draw will be significantly less, and so much less of a load on the contacts.  Personally I wouldn't hesitate to hard wire the sockets and so permanently eliminate the issue.
#3 rodrigo
rodrigo
    Chatroom Scare Crow
  • 7,417 posts
Posted 27 October 2011 - 09:28 AM
Well then I guess I have my answer for the Hard wiring.
LED's......someone's told me to do that.
#4 rodrigo
rodrigo
    Chatroom Scare Crow
  • 7,417 posts
Posted 27 October 2011 - 10:40 PM
Hey, TFT...will the LED tail light bulbs throw off the bulb out sensor?
Im thinking of replacing just the constant tail bulbs.
#5 Three Fat Tigers
Three Fat Tigers
    RWD Moderator
  • 1,746 posts
Posted 28 October 2011 - 12:03 AM
If both left and right side use the same lamp, the sensor should function normally.
The sensor has a coil of wire formed around a central reed switch, each circuit (left and right) have their own coil wrapped in opposite directions. When the load from both circuits are equal, the magnetic fields that are generated in the coils effectively cancel each other out and the reed switch that controls the dash idiot light remains neutral; only when there is an load imbalance does the magnetic field trip the reed switch.
#6 rodrigo
rodrigo
    Chatroom Scare Crow
  • 7,417 posts
Posted 28 October 2011 - 01:42 AM
Thank you Mr. TFT.
I'm thinking of restoring the green flexible circuit board and installing the LED's to substitute the bulbs on the tail lamps, I will be 4 bulbs total: 2 single filament (constant on) and 2 dual filament (constant on and brake).
Should I just jump in and just hardwire the tails..????
#7 Three Fat Tigers
Three Fat Tigers
    RWD Moderator
  • 1,746 posts
Posted 28 October 2011 - 10:46 PM
If you are going to do the LED lamps, I'd start with that, make sure the board contacts and those on the sockets are clean and in good order, maybe treat them with some CRC QD electronic cleaner, or even better: Deoxit D5S-6 contact cleaner. If the problem comes back (or you stick to normal lamps) I wouldn't hesitate to hard wire the sockets.
#8 ARD - Lucky
ARD - Lucky
  • 792 posts
Posted 29 October 2011 - 01:30 AM
Volvo actually makes a bulb integrity sensor delete plug.. You can find the part number in Vadis.
#9 rodrigo
rodrigo
    Chatroom Scare Crow
  • 7,417 posts
Posted 30 October 2011 - 02:27 AM
Thanks for the info guys.
Im going to start searching for the led's...but i have more questions as this is all new to me.
What intensity would be adequate?
These are 1057 dual filaments right?
White color would be ok yes?
#10 rodrigo
rodrigo
    Chatroom Scare Crow
  • 7,417 posts
Posted 31 October 2011 - 10:22 AM
So i orderd some 1157 18cell LED's with 360 lighting angle in red. Not the most intense but close.
West marine did not have what i was looking for but them seem to have a decent selection.
Got them from superbrightleds.com or something like that. A new tail light circuit board is waiting to be installed.
I hope this works
#11 esundell90
esundell90
  • 736 posts
  • Interests:Fast cars, mtn. biking, friends
Posted 02 November 2011 - 06:03 PM
Oh? Thanks for the tip, I might have to get a few.
-Eric-
Her name is Violet, She's my Wagon.
#12 rodrigo
rodrigo
    Chatroom Scare Crow
  • 7,417 posts
Posted 03 November 2011 - 11:31 AM
Got the bulbs in last night.
Pics will come.
#13 rodrigo
rodrigo
    Chatroom Scare Crow
  • 7,417 posts
Posted 04 November 2011 - 09:22 PM
Does anyone know if the dual filament bulb holders are specific to the left or right?
#14 Guest_Michaela_*
Guest_Michaela_*
Posted 08 November 2011 - 09:44 AM
I have a similar problem with my passenger side tail light. Both of my tail lights went out at the same time, but the left one had always been more problematic. I ordered circuit cards, and the left one works just fine, but the right one MELTED TWO of my other ones. Also, I think a fuse went out, because I no longer have lights in my dash after the incident. I have a third circuit card I bought, but I'm wondering if I did anything wrong...my main concern is grounding the two wires - from the circuit board, and the wiring in general. Should they not touch? I'm a girl. I know nothing about cars. But I know how to take something apart and put it back together the same way. I did it with the left, and the right is giving me a hard time. Any advice?
#15 rodrigo
rodrigo
    Chatroom Scare Crow
  • 7,417 posts
Posted 09 November 2011 - 12:57 PM
there are a few things one can do:
1. Hardwire the tail lights which eliminates the green circuit card. I opted to keep it original and have not had the time to spend hardwiring.
2. Install LED light bulbs and new cards. THe LED's will not emit as much heat and may not melt the cards.
3. Check all the ground connections are clean. Grounds can touch but a more qualified electrician may have something else to say.
4. Make sure the bulbs are in the correct way. When i got my car the previous owner had the index bayonette bulbs in place of the regular bayonette bulbs. The result: new bulb carriers.
#16 michaela
michaela
  • Validating
  • 1 posts
Posted 09 November 2011 - 10:11 PM
Ok. I figured out what the problem was with mine. I bought an after market circuit board. the one on the right does not fit well with the socket on the lower right hand side light. So one of the prongs was not touching circuit, and it burned up. I had to adjust the socket juuuust so, so that all 3 prongs were touching gold circuit. The only way to do this was to only secure it on half way. The left side is designed just fine, the right side is dumb. Tail lights work now, yay. Thanks! :)
#17 rodrigo
rodrigo
    Chatroom Scare Crow
  • 7,417 posts
Posted 10 November 2011 - 12:22 PM
well..i tlooks like I'm still going to end up hardwiring mine. :(
a bit of work, but positive results.
#18 phunktified
phunktified
  • 349 posts
Posted 15 November 2011 - 09:38 PM
anyone have the schematics for the 240 taillight wiring ?? going to have to hardwire a few of these for a friend of mine ..
Former: 89 744 GLE 16V, 90 745 GLE 16V, 95 964, 94 854 Turbo, 01 S40 1.9T, 99 C70 HPT, 01 S60 T5, 07 VW GTI
Current: 98 V70 GLT, 97 854 GLT
#19 rodrigo
rodrigo
    Chatroom Scare Crow
  • 7,417 posts
Posted 15 November 2011 - 09:48 PM
If my last attempt at repairing them doe snot work I will do the hard-wiring, but I also spent some time looking at the circuit board and tracing stuff out. It should be easy to see on the circuit board if you still have it on there.
http://www.k-jet.org...ng-tail-lights/
#20 James A Sousa
James A Sousa
  • 307 posts
Posted 16 November 2011 - 12:04 AM
I don't know about 240s but the bulb holders in 740s are definately different. They are different colors - green and white I thing.
When I had my first tail light issue with a 740 sedan - I swapped the bulbs to see if it was just a bad bulb - in short order i noticed that something was melting.
I did not find the problem until I removed both tail lights and took them apart and saw how the bulbs made contact on each side.
