Cold Start Engine Whine 98' T5
#21
Posted 15 November 2011 - 02:42 PM
#22
Posted 16 November 2011 - 04:07 AM
_HighVoltage_, on 13 November 2011 - 05:37 PM, said:
#23
Posted 16 November 2011 - 06:10 PM
#24
Posted 16 November 2011 - 06:48 PM
Quote
Mine does that! I think it's the turbocharger bearings, but not 100% sure, as it only seems to make the noise under load driving around.
Quote
(315): Good ideas don't start with we have a bottle of vodka
#25
Posted 16 November 2011 - 09:29 PM
Would this one do it just revving the engine in park?
#26
Posted 16 November 2011 - 10:07 PM
Me: "Yea."
#27
Posted 17 November 2011 - 05:53 PM
Big Will, on 16 November 2011 - 10:07 PM, said:
What's annoying with mine is that it ONLY does it (in colder ambient temps) under load while moving. No way to replicate it while stationary at all. I've checked every conceivable source of potential rattle/vibration. In my case, one of the only things left is the clutch/flywheel, but even there, it seems independent of engine rpm.
I don't feel that it is really of any concern, though. The pitch/level has never changed over the years, and nothing has failed as a result of it. Mainly, it just bugs me because I have not been able to locate it, and my car is very quiet & rattle free otherwise.
#28
Posted 17 November 2011 - 06:14 PM
Could it be the oil PUMP itself maybe?
#29
Posted 17 November 2011 - 08:21 PM
#30
Posted 17 November 2011 - 11:54 PM
No. Turbo's don't make the kind of noise I'm experiencing. When a turbo fails, trust me, you'll be fully aware.
Never ever heard of a whiteblock oil pump failure, (except some of the new cheap Volvo replacements), and again, my whine is more of a vibrational thing, definitely not an internal engine noise at all.
fields 100, on 17 November 2011 - 08:21 PM, said:
Good to hear you resolved your main concern!
#31
Posted 18 November 2011 - 12:08 AM
'05 xc/90. The stereo sucks.
#32
Posted 19 December 2011 - 06:15 PM
http://volvospeed.co...-cold-startups/
1997 850 GLT Wagon (LPT) - approx 160K miles, Koni FSD, IPD sways & endlinks, SAS delete
#33
Posted 20 December 2011 - 03:43 AM
#34
Posted 27 February 2012 - 02:40 PM
My car also developed the above-mentioned howling on cold mornings for first 30 seconds of driving. I had switched to synthetic at around 80K miles and the howl developed at around 105K (I have no idea if that matters, just another data point). After much reading, I assumed it was the oil sump pickup tube seal or the oil thermostat.
Well, three weeks ago, at about 107K miles, I changed the oil (and filter) and the noise was INSTANTLY gone. It has not returned at all. The only difference is that I put in conventional oil instead of synthetic since I was also adding Auto-RX. I don't know if something was lodged somewhere, and just the fact that I drained/filled the oil somehow corrected it, or if the difference in oil type did it. I doubt the Auto-RX made a difference since the problem was instantly corrected and Auto-RX takes thousands of miles to work.
I am pretty baffled, though happily so. We'll see if the noise returns when I eventually switch back to synthetic after the whole Auto-RX process. Of course, then it will be summer so the noise may not come back anyway till winter.
