So I was going on my first trip after replacing my bad TCV with the ac delco unit. I was trying to break the car in, after 20 minutes or so I stopped at a gas station and shut the car off. Came back out to start it and there were lights etc, but the starter wouldn't turn over. There was no clicking or cranking from the starter, and the lights stayed on. There were no warning signs before the incident. The battery is less than a year old, but i pulled it out to charge it anyway. It is too dark now to check, but i'm guessing I disturbed a wire/ground near the airbox/battery area since thats all that I disturbed. Is there any resource that shows the ground locations on the car so I can check them all tomorrow?
Car Won't Crank At All Shortly After Bcs Replacement
Started by 850_GLT_owner, Nov 13 2011 12:08 AM
delco bcs no crank 850r 850 volvo ground wire
7 replies to this topic
Posted 13 November 2011 - 12:08 AM
1993 Volvo 850 GLT 193,000mi
Back on the road Retired.
1997 850R 107,000
1997 850R 107,000
Posted 13 November 2011 - 12:51 AM
PNP?
Is your car an auto? If so, the PNP switch is a common cause of this type of issue....Ratchet the shifter back and forth 15+ times, and that sometimes will clean up the contacts enough so that the car will start.....
'94 855 Turbo
Posted 13 November 2011 - 05:06 AM
Also wiggle the ign. switch around some, another one of Volvo's quirks..........................TIM
1994 Volvo 850 Sportwagon
Posted 13 November 2011 - 05:20 PM
I've done both of those things...I had a friend turn the key last night and it sounded as if the bendix shoots out but won't try to turn the flywheel, so when i turn the key I hear a single click/clunk and thats it, no cranking.. I have an extra starter but i don't want to start throwing parts in on a whim. Do starters fail all of a sudden like that?
1997 850R 107,000
1997 850R 107,000
Posted 13 November 2011 - 09:05 PM
yes. starters will fail suddenly.If you here the bendix and the starter isn't turning, that's your problem.. Stick a pipe or breaker bar down onto the starter and tap with a hammer while someone turns the key..sometimes this will allow you to start it.
Another fucking s70: with Lots of zip-ties, a power antenna, and a bitchin shift knob... the only mods that matter.
Posted 14 November 2011 - 03:19 AM
Make sure your connections are tight on the starter. I went through the same thing and three starters before we figured out it was the connections working loose. Tighten up and see how things go.
Posted 14 November 2011 - 09:06 PM
Ended up being the starter motor...apparently the starter motor just had enough and died. It was off of my early model 93 850, so it had atleast 19 years on it. The warnings were subtle, slower cranking, but now that I have the new starter in it starts faster than it did before. It was a gradual decline. I guess it was just a coincidence that I installed the delco BCS right before this happened.
So in closing, my car wouldn't start, heard a single click when turning the key, no cranking of the motor what so ever. Tested the battery, checked the grounds that I could find(next to/below the battery tray, another one farther down that can be traced with the battery tray out) made sure all the connections to the battery/starter were good...ended up being the starter motor going bad on me.
1997 850R 107,000
1997 850R 107,000
Posted 15 November 2011 - 01:13 PM
Dang...Mine did this last night! One good solid clunk of the bendix and nothing...good power at ignition box.
It is still sitting in some lady's yard...I'll have to try the pipe trick before I have her towed home...
I guess I can't complain about a starter motor lasting over 300,000 miles and 14+ years
What is the replacement part of choice?
1998 V70 T-5 -Auto - ARD Blue & Turbo-Tuner,18T, HD TCVw/ Hallman Pro MBC, custom 3" DP w/ Volvo 2.75" sport catback - both wrapped and coated, RIP, IPD aluminum intercooler, intake w/ K&N cone, R ex. manifold, , gasket matched & polished intake manifold w/ thermoblock spacer, n/a TB w/ 960 plate, Optima bluetop, MSD 6aD and blaster coil, IPD plug wires, IPD poly bushing, Koni FSD w/ Eibach springs, IPD sways 25mm x 25 mm, blue silicone vac, silicone coolant lines, custom intake tubes grill to turbo, skid plate, front lower brace, cherry turbo strut brace, HD endlinks, 302mm brakes, Zeitronix wide-band/data-logger, Walbro w/variable fpr. In process: Home grown HD Endlinks, Meth/H2O injection, greens, catch can, fully built 2.3.
