Coolant Leak, Pictures Inside
new radiator? i hope not.
22 replies to this topic
#21 lookforjoe
lookforjoe
  • 8,311 posts
  • Interests:Making Stuff
Posted 20 November 2011 - 03:03 PM
View Postthe commissar!, on 14 November 2011 - 04:02 PM, said:
Look in the performance threads for a beautiful custom radiator that LookForJoe had made... It was ~$450 but DOES NOT have provisions for oil and tranny coolers built in if you need those...
That is very tempting for the next time I have to replace mine...I already have an aux. tranny cooler and have plans to upgrade to the newer 99+ style oil pan with external cooler...food for thought.
They can add coolers to any spec - not sure about the couplers, though.
For the OP - a simple aftermarket rad would work fine - I buy them off the eBay vendors, usually no more than $125-150. The construction is all the same. Some offer lifetime warranties, too.
#22 KS70T5M
KS70T5M
  • 553 posts
Posted 21 November 2011 - 06:04 AM
I think I'm going to go for OEM, the problem is whenever I've called Tasca in the past it doesn't seem they have lower prices than anywhere else, do you need to say you're from VS or something?
'98 S70 T5M
17in. pegs, EST springs, Bilstein Tourings, Jewels with 5000K HIDS, 5000K HIDs in fogs, straight pipe from cat, intake, Dawes mbc, prosport boost gauges, ipd hd tcv, samco intercooler hoses, ipd vac lines XC grille/mesh grille, R bumper, 35% tint, ariel down switch, blitzsafe ipod adapter, EST eylids
<a href="http://www.cardomain.com/memberpage/639765" target="_blank">http://www.cardomain.com/memberpage/639765</a>
#23 KS70T5M
KS70T5M
  • 553 posts
Posted 21 November 2011 - 06:10 AM
Tasca's site lists 3 different radiators but no differentiation in brands????
'98 S70 T5M
