Manual Transmission Cold Shifting Issues
Posted 14 November 2011 - 07:23 PM
Syncros going?
1994 Volvo 850 Turbo Manual
ARD Green Tune | FMIC | OBX Turbo Back | Angled 16T | IPD Springs
Posted 22 November 2011 - 10:30 PM
1998 Volvo S70 T5M 183k
Posted 22 November 2011 - 10:53 PM
Posted 22 November 2011 - 11:07 PM
2011 Volvo S60 T6 AWD
Posted 23 November 2011 - 01:04 AM
(n)A-GAME, on 22 November 2011 - 11:07 PM, said:
Posted 23 November 2011 - 03:19 AM
850T5M, on 14 November 2011 - 07:23 PM, said:
Syncros going?
Kinda normal for winter. Going into second and then first used to work for me when 1st wouldn't go in from neutral.
1998 Volvo S70 T5M - 04 R Motor - T3 60Trim @ 19PSI - 3" Custom Exhaust - TT/MegaSquirt 3X - FMIC w/ 3" piping - TA Coilovers w/ Custom Rears
Posted 23 November 2011 - 05:03 AM
_HighVoltage_, on 22 November 2011 - 10:53 PM, said:
Both do. Rare to have reverse.
Reverse gear is usually not synchromesh, as there is only one reverse gear in the normal automotive transmission and changing gears into reverse while moving is not required. Among the cars that have synchromesh in reverse are the 1995-2000 Ford Contour and Mercury Mystique, '00-'05 Chevrolet Cavalier, Mercedes 190 2.3-16, the V6 equipped Alfa Romeo GTV/Spider (916),[1] certain Chrysler, Jeep, and GM products which use the New Venture NV3500 and NV3550 units, the European Ford Sierra and Granada/Scorpio equipped with the MT75 gearbox, the Volvo 850, and almost all Lamborghinis and BMWs.
1995 855 GLT (stock). 2006 XC90 Ocean Race. 1 of "only" 800 (says so on the dash).
Posted 23 November 2011 - 12:42 PM
'05 xc/90. The stereo sucks.
Posted 23 November 2011 - 02:26 PM
My M58 shifted great with the Redline Fluid in it...I don't think it's any worse than any other synthetic GL4 fluid. The M66 in my old S40 was a bit stiff in 1st and 2nd when it was below 0 out up in Maine on the factory fill.
Anyway, you can always change the fluid to see if that helps the cold-shift issue.
Me: "Yea."
Posted 24 November 2011 - 04:28 AM
When I say cold temperatures, I mean anything below like 5-8 degrees celsius.
Basically, the shifter is very notchy, which is fine (cuz it still goes into gear)...Reverse, I dont really care much about it, I know its sometimes hard to get in it, but we dont use it at every stop sign.
My problem is basically only first gear. The only way it will go into gear is if I do a full complete 100% stop. It wont go in if im barely rolling, im talking like 1-2km/h...its really annoying cuz the car is moving too slow for 2nd gear (burn the clutch)...The only way to get it into first, would be either to do a full stop, or like put it in second, then rev the gas and put in first...it just gets all jammed.
Idk how else to explain it. This is my first manual car, I know theres a lock so you dont go into first while moving, but its rediculous that it wont go in even at such a slow speed. In the summer it works fine.
Any ideas?
Also, I always let the car warm up before driving off...but this continues to happen even when the car is hot (after a 45 minute drive).
Posted 24 November 2011 - 01:53 PM
Posted 24 November 2011 - 03:21 PM
scumcity14, on 24 November 2011 - 01:53 PM, said:
And when ur in a rush to take off, you have to play with the shifter and gas, etc...
I figured theres something wrong with something lol :s
