Work Emotion Cr-kai
wheels help work offset
16 replies to this topic
#1 s_moneh
s_moneh
  • 1,166 posts
Posted 16 November 2011 - 05:33 PM
http://www.workwheel...ory=27&wheel=80
i'm looking at getting possibly a custom set of these. anybody have any ideas what would be ideal on an 850?
i'm down for a 17x8 size in possibly the deep concave set my only issue is offset, i've never known how to calculate it nor fully understand it.
dont mention the fenders because fender work will be done i just need an offset that will clear BBK and not rub on the inside.
also is it recommended to run staggered? as in 17x8's all around but offsets different from the rear to the front?
#2 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 16 November 2011 - 05:46 PM
What you need to know is backspacing. You can have a 0 offset wheel but if it has a crazy spoke profile it will clear bigger calipers. I would try to stay in the tried and true 38 range.
#3 Overboost850
Overboost850
  • 1,537 posts
Posted 16 November 2011 - 06:23 PM
Great wheels. Be ready to wait 6-9 months for a custom set.
Brendan - '10 FA5
#4 gilber33
    Level 6 Senior Member
  • 11,110 posts
  • Interests:you
Posted 16 November 2011 - 06:31 PM
There's no point in running staggered wheels on a FWD car for performance purposes.
willtheyfit.com
http://www.jonathanr...fset-calculator
Use those two sites to see if they'll fit and how they will look. You want a max inset of 147mm and poke you want to be around 75mm of poke in the front to be flush with the outer fender. The fender in the front is approximately 78mm out from the hub to use on the second site. Not sure on the rear hub to fender distance, but just measure your existing wheel to the edge of the fender, look at the poke of your existing wheel and add those together and that's where you would want the other wheel to sit.
1994 850 Turbo | Rica Stage III | Poke and Stretch
#5 s_moneh
s_moneh
  • 1,166 posts
Posted 18 November 2011 - 03:58 AM
thank you for that info! i will use that and spend a few days calculating aha
#6 Johann
  • 4,979 posts
Posted 18 November 2011 - 08:15 AM
Nicest fit on 8j would be around ET43.
#7 Egger
Egger
  • 12 posts
Posted 18 November 2011 - 11:59 AM
little note:
i bought 18 month ago work emotion xt-7 wheels for my skyline r32 gtr in matte bronze.
after little time the paint on the wheels start to peel off.
they were very very bad painted! i had to do a repaint because it was so bad on all 4 wheels!
#8 Mesoam
  • 18,673 posts
Posted 18 November 2011 - 01:31 PM
do you have any pictures of that?
96 854 R, CLICK ME
The Jeep
#9 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 18 November 2011 - 02:11 PM
View PostEgger, on 18 November 2011 - 11:59 AM, said:
little note:
LOL powder coating.
#10 gdizzle
  • 19,804 posts
Posted 18 November 2011 - 02:34 PM
Truth. But last I heard WORK USA was gearing up to be able to do production state side. Currently, if you have any issue w/ your wheels, all warranty work is done in Japan. :lol:
#11 s_moneh
s_moneh
  • 1,166 posts
Posted 18 November 2011 - 08:45 PM
damnnn maybe its worth a wait till it at least reaches stateside aha all this info's great well see what happens in the end, i need a great light set for track :(
#12 s_moneh
s_moneh
  • 1,166 posts
Posted 23 November 2011 - 01:08 AM
ok this is a phail! cant use these without adapters
Thank you for your e-mail.
Unfortunately we won't be able to assist you with your needs due to two
reasons:
1. Emotion CR Kai will be replaced by the Emotion CR Ultimate in 2012 so we
are not taking on special PCD (5x108) right now.
2 All 17x7.0 and 17x8.0 are all flat face (no concavity) and the lowest
offset we have on 17x8.0 is +32.
Let me know if you have any other questions.
#13 Raintracks
Raintracks
  • 906 posts
  • Interests:1521
Posted 01 December 2011 - 09:36 AM
You need to run more an agressive set up and anything below 17x9's have no concavity. They're either plain ugly or the spokes are poking out of the center even on a side view angle. Not good to look at.
Run the 17x9 +22 all around.
///VST ¤ KW VARIANT II . JAYSONIC™ ¤ BLITZ ¤ LEVOC ¤ EUROSPORT ¤ SPR ¤ RäZO ¤ T.E.L. ¤ XENTECH 6.K.3.
#14 devolv
devolv
  • 452 posts
  • Crew:ECC
Posted 08 December 2011 - 02:20 PM
Get these, and redrill them to 5x108.
http://www.stancewor...ead.php?t=23850
97 850 GLT LPT 16T - EST Intake - EST Strut - Ferrita Exhaust - KW Coilovers - Undergoing S70/V70R front end retro fit ;)
04 S60 R - 6 MT - Titanium Grey - Nordcap - Sport Kit - Painted Trims - BBS CK 19x8 - CFW CF VST Front Lip - AEM Dryflow Intake - CFW PCC Spoiler - CFW CF Roof Spoiler - Clear headlights + 05+ Custom LED Tails - Eibach Springs - UltraRacing Strut Bar - Autovation Pedals - TWM Short Shifter + M1 Abrams Knob - 05+ Center Console
#15 s_moneh
s_moneh
  • 1,166 posts
Posted 08 December 2011 - 10:21 PM
how much is redrilling gunna cost?
#16 Raintracks
Raintracks
  • 906 posts
  • Interests:1521
Posted 10 December 2011 - 05:32 AM
It all depends where you go. Shop around!
$25-$35 a wheel is a good price.
#17 gilber33
  • 11,110 posts
  • Interests:you
Posted 10 December 2011 - 06:07 AM
Those will have to be filled and redrilled, so you'll have to refinish them too. Backs aren't flat so you can't just do a redrill along with the fact that the raised parts on the back already have holes.
Also tagged with wheels, help, work, offset
