Custom Gauge Panel For 850?
Started by KS855R, Nov 16 2011 09:59 PM
10 replies to this topic
Posted 16 November 2011 - 09:59 PM
Has anyone on here made a custom Gauge panel for a 850. It should be easy with fiberglass but was wondering how hard it will be to wire up the gauges with the stock wiring.
Posted 16 November 2011 - 10:35 PM
They make 3 pod blank plates that go under/over your cd player. But if you want something big on the dashboard that's a different story.
The name's Ben: '95 850, m56 w/ gripper lsd, SBC feramic clutch, built '02 RN 2.3L, worked '04 R head, Enem Y21 cams, Precision 5857B, ARD tune, blah blah blah
Posted 16 November 2011 - 11:55 PM
This is my attempt in a p1 v70
UK spec '97 V70 T5M
Posted 17 November 2011 - 09:02 PM
Stack or AIM is who I usually use.
Volvospeed On Google+
Posted 17 November 2011 - 11:22 PM
UK spec '97 V70 T5M
Posted 18 November 2011 - 01:45 AM
no a-pillar mounts?
Posted 18 November 2011 - 02:33 AM
i dont smoke so yea
Posted 18 November 2011 - 08:39 PM
Thanks for the ideas guys, I found out that you can use the 1998 V70 instrument cluster so I am going to do that and then do what s_moneh did! Although I might do fiberglass and make it look a bit more OEM
Posted 18 November 2011 - 08:44 PM
yea thats my prototype i ran for this year i plan on making it more oem looking to properly fit 5 guages as well or i may redo it and vinyl wrap it in black, that's in the air. But this is the best i think it keeps the cops from looking. I used to run the a-pillar and that stuff just shines out the windows like a night club i always had onlookers and figured i wanted the more sleeper look where you couldn't see it right away.
Posted 18 November 2011 - 11:29 PM
I am trying to keep as low key as possible myself! Its not a sleeper when you have 5 bright gauges in clear view of all other drivers. I plan to keep my boost gauge on the pillar though
