Wilwood 4 Piston 302mm Bbk For 850/x70
32 replies to this topic
#1 B Mac
B Mac
    Ginger Beater
  • 3,957 posts
Posted 17 November 2011 - 12:09 PM
I've been working on this for a while with my buddies over at Chassis Dynamics here in CT. It utilizes any of the standard 302mm rotors, a custom bracket, and a slim Wilwood 4 piston booted caliper.
It takes about 30 seconds to change pads on these suckers ;)
The wheels we have test fitted these with include:
17" Volans: no spacer required
16" Solar: 5mm spacer required
15" Draco: 15mm spacer required
15" Aries: 15mm spacer required
15" rear wheel drive offset steel wheel: 15mm spacer required
Pay no mind to the purple half...
With all of the recent builds going on this seemed like a perfect kit. We all want better brakes, and the 13" R rotor makes for an awesome base to stick a larger caliper on but you have to factor in the price of a 17" wheel and tire combo as well and sometimes a spacer. 17" is the smallest you can go, which means you're also buying snow tires if you live in an area that experiences what some call "winter".
The idea behind this kit is that you can get superior stopping power over the oem Volvo caliper, yet you can keep the wheels you currently have on the car. For anyone that goes to a drag strip, 17" wheels are a joke. You need a smaller diameter wheel for drag radials or drag slicks. In addition, for anybody that does autox, you might want to change your pads over if/when you put on your autox wheel/tire combo. Changing the pads literally takes 30 seconds or less. We are working on a video to demonstrate pad replacement.
We are currently waiting on the second bracket to me machined and will be testing these asap so stay tuned!
Edited by B Mac, 17 November 2011 - 12:14 PM.
The name's Ben: '95 850, m56 w/ gripper lsd, SBC feramic clutch, built '02 RN 2.3L, worked '04 R head, Enem Y21 cams, Precision 5857B, ARD tune, blah blah blah
#2 Mesoam
  • 18,673 posts
Posted 17 November 2011 - 12:56 PM
the big question is of course....will they squeal....i vote to test on my car
96 854 R, CLICK ME
The Jeep
#3 trs80
trs80
  • 435 posts
  • Interests:Anything with a fossil fuel power plant.
Posted 17 November 2011 - 01:39 PM
I like where this is going. I have been holding off on a BBK due to having 16" wheels for snow tires.
'97 850R, resto phase. Mods in Garage: Volvo 850 R (1997)
'96 Jeep Cherokee, lifted, locked and ready for rocks.
#4 lookforjoe
lookforjoe
  • 8,311 posts
  • Interests:Making Stuff
Posted 17 November 2011 - 02:07 PM
Nice work Ben! Good to see it's close to fruition!
Do they have a deeper/taller pad that will pickup that inner area, or are you thinking it will be sufficient as is?
#5 gilber33
    Level 6 Senior Member
  • 11,110 posts
  • Interests:you
Posted 17 November 2011 - 02:17 PM
I am of much interest! :)
1994 850 Turbo | Rica Stage III | Poke and Stretch
#6 B Mac
B Mac
    Ginger Beater
  • 3,957 posts
Posted 17 November 2011 - 02:38 PM
Thanks Hussein!
That's the only downfall about this kit : we don't get a full sweep of the burn path of the rotor. Regardless, it will still work much better than the stock caliper according to the total area of the pistons. It will also dissipate heat more effectively due to pad composition and the caliper being made of all-you-mineum.
#7 gdizzle
  • 19,804 posts
Posted 17 November 2011 - 02:46 PM
What's the target price? I'm not really seeing any huge benifits of these w/ the smaller rotors + smaller burn path, only upside being clamping force. It seems to me it'll be negligible. I'm sure it'll stop fine, but will it be any better than the oem girling setup? Have you done any stopping test w/ the oem setup to compare with this kit once installed? I'm not trying to be a wet blanket, and think the quality of the work done is fantastic, I'm just not seeing this as a worthwile investment, cost of kit + effectivity of upgrade.
#8 gmsgltr
gmsgltr
  • 3,654 posts
Posted 17 November 2011 - 02:57 PM
same calipers or very similar on our FSAE car... they were free... i feel like taking them now lol
nice work ben!
- Greg - 96 Red/Tan 855 R 96k miles -
FOR SALE: Used 75k Miles OEM 16T Turbo/Angled/Ipd HD CBV - PM ME
#9 B Mac
B Mac
    Ginger Beater
  • 3,957 posts
Posted 17 November 2011 - 04:19 PM
Greg,
We are working on the pricing and trying to get the best deal we can. As far as testing goes I have another car with a 302mm kit that I will be doing comparison tests against with 60mph-0mph as well as 100mph-0mph. Wilwood uses proprietary pads as far as I know so you'll have to choose from their choice of compositions. For the test car, we will use off the shelf performance pads (akebono, mintex, oem blue box, etc.) The only way to find out if they're better or not is to test!
Edited by B Mac, 18 November 2011 - 04:44 AM.
#10 tizio
tizio
  • 315 posts
  • Interests:all engines, some cars,space, ho knows
Posted 17 November 2011 - 05:08 PM
Hey Ben, nice job men!!
Have a question here, you will do the test on the two cars with the same model pads?? just to see the clear the dif. in stop power!! I guess you already plain this just asking!!
#11 flyfishing3
flyfishing3
    100% Vegan
  • 12,655 posts
Posted 17 November 2011 - 05:41 PM
Double R garage
i was so drunk last night, i thought the toothpaste was astronaut food.
#12 Ian Carr
Ian Carr
  • 1,386 posts
  • Interests:Autos, design, photography, beer.
Posted 17 November 2011 - 05:50 PM
Ben,
Glad to see the work in progress, I'm sure it will be a very nice set up over 302 with volvo carier style calipers. Can't wait for you to get them on the car and see what they can do.
Ian Carr - 99' Volvo S70 T5M - 86' Porsche 944 Turbo - 07' Mazda 3
True CAI, Neptunes, XC bumper, iPd25mm rear sway, short shifter, front mount, ssqv, sweet license plate mounted in the engine bay, D2's
#13 adamjjohn203
adamjjohn203
    Steve
  • 1,960 posts
Posted 17 November 2011 - 06:46 PM
:tup: :tup: Nice work...thanks for the R&D!!
#14 theForgottenone
theForgottenone
  • 3,977 posts
Posted 17 November 2011 - 09:24 PM
It look great. Full sweep of the rotor by the pad would be so much better.
#15 FCP Groton
FCP Groton
  • 1,838 posts
Posted 18 November 2011 - 12:29 AM
This BBk kit is a fantastic idea. You will definitely sell a lot of them being that you do not need to replace your wheels. If anything, you just need a spacer.
Andrew Owendoff
#16 s_moneh
s_moneh
  • 1,166 posts
Posted 18 November 2011 - 12:34 AM
anyway u guys can get ur hand on a set of bbs propus c's to see what the clearance is on those? this is like a defiante upgrade for me!
#17 boosted_brick
boosted_brick
  • 544 posts
Posted 18 November 2011 - 01:40 AM
bbk ftw
#18 NEU
NEU
    Old Man Crew Photographer
  • 2,982 posts
Posted 18 November 2011 - 02:11 AM
Good work Ben. What is the plan for brakelines? Braided? Curious to see your test results too.
NEUBAR
#19 B Mac
B Mac
    Ginger Beater
  • 3,957 posts
Posted 18 November 2011 - 04:56 AM
Unfortunately this is best that we can do as far as a burn path. Although you're missing a bit of the rotor, it isn't that much. But as I said above, the only way to prove otherwise is to test...and test...and test :)
If you guys can contact H&R about hub and wheel centric spacers/extended lug nuts that'd be awesome!
Matter of fact, I can probably steal a wheel from my buddy Bobby because his coupe is at the body shop and I'll just trade him a wheel for a day. I might have access to some Tritons if Travis is cool with parting with one as well for r&d.
That's our next step Neu! I have a set of braided lines that are brand new for oem calipers. We'll use those to get the proper length. The only issue we have is that with the stock calipers, the line threads into the caliper at a 45*ish angle where with the Wilwood caipers it goes in perpendicular ( 90* ). I'd like to find a 45* swivel 1/8th npt hydraulic fitting to use on the caliper side. The rest should be simple.
#20 s_moneh
s_moneh
  • 1,166 posts
Posted 18 November 2011 - 05:10 AM
sweet! i cannot wait for some testing! aha
