Hello all
I haven't owned a 240 in a few years, so I'm a bit rusty (no pun intended). I've been called to duty on a friend's wagon, and I'm not quite sure where to start. I think my question is fairly basic though, and the problem is probably nothing unique to this car.
So my friend has a '91 245 SE, and she could not get it started the other day. She said that she experienced some hesitation once during a short trip to the gas station; after she got the tank filled, she could not get the car started again (it would crank, but not turn over).
When I went over there to see what was going on, I tried starting it first to confirm what she had said, and it did crank (but not turnover). I gave it a little bit of gas on the second attempt, and it started--it seemed ready to stall once it did start, so I tapped the gas pedal again, and it stabilized. We drove it around right after, and it gave me no problems in terms of hesitation and such. It ran just like your typical 240.
This afternoon, she had the same problem apparently. She said she tried giving it gas, but that did not work. One possibility is that she may have flooded the engine. Either way, I'm trying to figure out what to check first, because I'm headed over there tomorrow to see what may be going on. Could this feasibly be a fuel or fuel/air mixture problem? I was thinking clogged fuel filter, dying fuel pump, or the infamous air mass meter? In all of these cases, what steps should I take to rule anything out? I'm pretty solid on repairing things, but suck on diagnosing ...
Thanks for any help!
Thanos
Trying To Help A Friend Get Her 245se To Start
Started by Turbowagon245, Nov 18 2011 01:32 AM
air mass meter fuel pump fuel filter 240se
4 replies to this topic
Posted 18 November 2011 - 01:32 AM
Posted 18 November 2011 - 01:45 AM
Sounds like fuel as you said and you could start with the obvious. Fuel filter, and assure the injectors are not leaking down. Sounds like you have a good background to check the basics and report back. From what you gave us it could be almost anything.
Volvospeed On Google+
Posted 18 November 2011 - 01:14 PM
Fuel Pump Relay, under the pass kick panel...
Posted 18 November 2011 - 10:16 PM
forehead slapper of the day: fuse number 6 (fuel injection system) was loose--that's all that it was.
Posted 19 November 2011 - 11:19 AM
Nice that it was an easy one.
1989 BMW 325i - 1992 Volvo 240 - 1992 Vespa PX200E
1993 Bridgestone RB2 'porteur-plaisir' conversion - 1995 MASI Gran Corsa - 1996 Gunnar Roadie
