Posted 20 November 2011 - 03:18 AM
So with that in mind, and this isn't my first time around the block, but it is with a turbo'd car.
I was IPD and saw a intake spacer for I think 60 or so bucks? Anyone try this and notice anything? Also the R exhaust manifold is this really an upgrade and notice anything? If I put this on my car will I have to change out other things for it to fit? Or is it all bolt on and go (so to speak)
Lastly I will have the head pressure checked, and milled if need be, and I've heard its a good time to do the valve stems as well, so I may do that as well. Other than that this is what I know will be done
-head gasket
-intake and exhaust gaskets
-new radiator
-clean out all the turbo tubes and intercooler
-clean out the intake and TB
-clean the engine (piston tops and walls)
-new timing belt
-new water pump and t-stat
-clean out all the silicone elbows that are aftermarket (lucked out there!)
Then the extra that I'm thinking about doing...
-R manifold
-intake spacer
-larger injectors
Anything else???? I'm looking to be budget minded and keep it pretty simple till its up and running as it should be, but I feel the intake and the R are easy upgrades that wouldn't cause too much headache at the computer!
1997 850 T5 2.3 Stock, Silicone hoses, Debadged blacked out grill, 95 2.3 engine, drop in K&N
1987 Jeep Cherokee (Terakee) too much to list for mods
Posted 20 November 2011 - 03:59 AM
Larger injectors aren't going to do anything for you, unless you get a modified tune.
Intake spacer is a minor improvement, mostly reduces heat soak when idling. 3" TB w/960 butterfly & bore out the intake will make more of a noticeable difference.
R exhaust manifold is an improvement, but you really want to plan on an upgrade to the rest of the exhaust as well.
Posted 20 November 2011 - 05:48 AM
Posted 20 November 2011 - 06:06 AM
2005 S60 T5 Manual 147K miles;2001 S60 T5 Manual Totalled 9/6/12 at 235K miles
1997 854 T5 212K - son; 1995 854 NA Auto 240K - daughter
Posted 20 November 2011 - 06:46 AM
PS: STAGE "0".
98 S70 T5 M56H,R clutch,manifold , 04 RN engine, Black on black,Koni+Ipd Black, IPD Sways, OZ racing 18X8,282K, 00'V70R silver/black STOCK for now. 99' C70 Vert., 02' S60 AWD.
Posted 20 November 2011 - 09:24 AM
"angled hot side" <<< what is that
3" down pipe <<< off what? also doesn't cutting out the cat really help, and being that I just blew water vaper threw it?
I need to find a 850 na throttle boday and fine a 960 "plate"<< what is this
oh and yes the head will be going in to get checked out and tested and milled if need be
Posted 20 November 2011 - 02:00 PM
Second what is your budget
third what are your plans after it is done?
Reason for my questions.
First: you maybe better off getting a used motor if you're close to someone parting one out
second may cost you more than just getting the motor if you do headgasket
third
- if you plan to keep it and drive it till the wheels fall off, dont have a small budget and do ALL the stiff that is a bitch to get to. this will save future blood sweat and tears
- if its to turn over and sell, not the right car to do it with. not much market for a great used 850
- be concerned to get her up and running first. then do the go fast stuff. phelonic spacers, r mani, FMIC,tune, cbv block off, hids, r bumper, fogs, ect ect will make the budget go up. so get the car running, then dump money into it. at least thats what i did and my project came out awesome.
- PCV system
- turbo drain o-ring
- oil dip stick o ring
- heater core hoses
- lower radiator hose
- upper radiator hose
- coolant temp sensor
- all new vacuum lines
- trans flush
- heater core
- alternator
- starter
- b+ cables
- i'd get the head kit, it comes with 99% of the stuff you need
- NEW HEAD BOLTS
Beg borrow steal what ever you can do and get a http://buy1.snapon.c...&group_ID=17510
i kid i kid...but its a awesome tool
reference this thread since it is still fresh in my mind http://volvospeed.co...-t5-manual-v70/
i use this guide
http://www.tracystru...s/850hg/p1.html
3 cars 1 driver 05 V70R GT http://tinyurl.com/c6frorm, 01 C70 T5M Vert http://tinyurl.com/75zhepq 03 4Runner http://tinyurl.com/ck254ueSoLD 03XC90T6 http://tinyurl.com/74pwukq98V70T5M http://tinyurl.com/85mh7z3 97 850R BTCC http://tinyurl.com/7rx7naw 98 S70T5A http://tinyurl.com/c32vjbf
Posted 20 November 2011 - 07:05 PM
Lastly I do have a budget, but the nice thing about this car is that I DON'T NEED IT so it doesn't have to get fixed right tomorrow or anything it could stand to wait a month or two... but I'd really like to be driving it now though!
Posted 20 November 2011 - 07:15 PM
do all the stuff i suggest, why? You dont wanna go do it when it does fail and burst and leaves you stranded.
heater core is cake, the heater lines are right there.
dont assume, you may regret it later. expect it to be bad. look at it like this, you rebuild everything back to oem spec, its like a "new" engine and you will not have to do it again for another 10 years
My v70 was a over heat = head gasket well cared for car too. i dont like to take little things for granted, $8 lower rad hose, $30 in heater core hoses...come on if you are doing that much work already, whats another 5 minutes to change out the hoses and now you are sure it will last another 5-7 years minimum....peace of mind is priceless. the pcv system is a cheapo replacement while you have it out, basically putting on new parts vs reinstalling the old.
You should be the "do it once and forget about it" mentality if its a keeper. Constantly wrenching on a car is not fun.
I'd ditch the R mani in favor of new parts going on the car. Even though i just got my FMIC order in yesterday for my v70 and cbv block off is on the desk in front of me. i still have 250 miles till the car gets broken in then the mods begin! LOL
Posted 20 November 2011 - 08:52 PM
Posted 21 November 2011 - 12:32 AM
what are the B+ cables? and I agree with ya, I mean if I'm there why not, and its easy stuff like ya said, just more turning on wrenches and parts! So anything on removing the cat? I don't need one up here so....
B+ are the battery positive cables. they tend to corrode and dont provide the car with enough power.
why remove the cat? does it offer up major power gains? no. is it bad? probably not. does it stink? yes it will. can it kill you? yes. why is this such a thorn in your side(meaning me)? there are minimal gains with maximum eco impact #1, two i hate the way it stinks to high hell.
i think you have a large cat like mine...i am going to take another look see tomorrow.
read thru my project v70 and you will see what i did
Posted 21 November 2011 - 03:35 AM
Posted 21 November 2011 - 04:03 AM
I've personally never seen a HG failure on a 870 due to heater core leakage, though. I've seen the cores leak to the point of removing at least a gallon of antifreeze from the passenger compartment. Of course, if you let the system get low enough for long enough, it is possible that HG failure could result.
#14
Posted 21 November 2011 - 05:08 AM
#15
Posted 21 November 2011 - 12:23 PM
One of the causes of a head gasket failure is that the heater core inside the cabin has started to leak, and after there is a loss of fluid, the engine gets hot, and blows the head gasket. My local mechanic was a dealer mechanic for years, and he says that these engines don't seem to blow head gaskets unless something else caused it (one poster did have a broken head bolt, and that could cause the problem) The first place he looks is the heater core, and he hates those, because it means taking the entire dash out on some cars, and it it a very long job, even for someone who has done it dozens if times, and knows all the short cuts. I'd suggest checking that, because if it is leaking, you will only have the same problem all over again.
thats right on. i replaced my heater core for the same reason too. why risk it
^ you know our heater cores take less than an hour, right?
for the first timer, 1 hour...experienced, 1/2 hour. right now when doing the head gasket is the best time to do it. i had all of 2-4 cups come out, normally on a routine maintance swap out, you'll make a HUGE mess.
#16
Posted 22 November 2011 - 04:05 AM
#17
Posted 27 November 2011 - 03:17 AM
360-204-8748 text me as I hardly get service. I know a used engine from a engine dealer is 1500... id like not to spend that much :/
I'm in Bremerton WA 98312 is my zip.
#18
Posted 27 November 2011 - 03:52 AM
#19
Posted 27 November 2011 - 07:12 AM
#20
Posted 27 November 2011 - 06:17 PM
Search ebay for used engines, you could get lucky and pick up a nice RN motor too...
