8 replies to this topic
Posted 22 November 2011 - 09:19 AM
Here is my problem. About 3 months ago on my t5m, the car started shuddering and such. Pulled the code and it said it was an injector problem. I swapped fuel rails with my old known working t5 fuel rail. Now I am home on break and attempting to fix the car.
Car is still running like a bag of dicks. I have replaced injectors and fpr. There is still a check engine light on, but I do not have my code reader available to check (I assume its for the injectors again). I will put a video up.
Symptoms:
-feels like car is not running on all cylinders
-while stepping on gas a little, engine sounds like a lawnmower engine at full throttle (not a weedwhacker/honda)
any help will be greatly appreciated
Symptoms:
Posted 22 November 2011 - 11:23 AM
read the codes
read the codes
read the codes
becha its a P30X code, for mis fire. Also does it smell like fuel not burned from the tail pipe? Might be time for plugs, cap, rotor, and wires.
fcp coupon code cyberweek 15% off
read the codes
read the codes
You want Volvospeed stickers?--->http://tinyurl.com/7axjudr
Posted 22 November 2011 - 12:34 PM
get codes, check plugs and wires.
Posted 22 November 2011 - 08:49 PM
Change those wires and also check the connection to your MAF sensor. There was a recall some years back, all you need is a large zip tie to fix. Pull the MAF sensor wire down by the connector and tie it to the body.That could be the reason for the check engine light.
Posted 22 November 2011 - 10:32 PM
pull your plugs and check out how fouled up they are
Jake
1998 Volvo S70 T5M 183k
Posted 23 November 2011 - 06:34 PM
okay. i replaced plugs with ac delco coppers gappers to .028
car still runs like this
brand new. i wish i could read the codes, no code reader (its in cali), and car does not have plates (no driving)
Ihatespeedbumps, on 22 November 2011 - 10:05 PM, said:
Brand used? Like Ghost said read the codes and start from there!
Edited by thewhiteguy1, 23 November 2011 - 06:38 PM.
Also tagged with fuel issue?
Maintenance →
FWD/AWD 1998 and Prior →
98 V70 Fuel Filling IssueStarted by theodore, 19 Feb 2012 |
