Lifters? Something Else?
lifters oil clacking
63 replies to this topic
#1 Kevin.
    Dick Dabber
  • 5,447 posts
  • Interests:United States Air Force
Posted 27 November 2011 - 03:40 PM
I've been plagued by a problem for the last year or so with my motor. Sometimes after I start y car it will make a significant ticking noise. I know what they motor is supposed to sound like and this is louder than it should be. It also does it after I've been driving for awhile as well and I have no idea why it's been doing this. Its a very distinctive clacking noise, but usually a light touch of the throttle will fix it :huh:
I already did my oil pan gaskets, just did the PCV recently; I don't know what the hell this is. Help?
Running 10w30 full synthetic
95 850 GLT | Tropic Green Metallic | 219k | ARD Tune | M56H | E-Code Conversion | Full LED interior
2W131L - USAF
#2 Rsterns
Rsterns
  • 943 posts
Posted 27 November 2011 - 05:45 PM
If you've done the oil pan seals and the PCV, and your still getting a ticking noise that goes away with a little throttle, that says to me that you have a problem with a lifter, or maybe that o'ring slipped out of place when you did the pan, and your not getting all the top side pressure you deserve for your efforts.
'98 V70 T5 (Auto) At 280,000 fresh rebuild with port and polish ;Cryo treated everything, IPD Stage III w/ IPD Intercooler and TME cat back exhaust,Koni FSD/ Eibach springs, IPD sways F/R, IPD HDEndlinks, IPD BBK; Slide Show of build: http://rides.webshot...563883893OGxoym '96 965 A sweat find with 30K miles on it! http://rides.webshot...myd?vhost=rides
#3 Kevin.
    Dick Dabber
  • 5,447 posts
Posted 27 November 2011 - 06:46 PM
Another thing I've noticed is that I drive the car hard my lifters clack horribly. Turning off be car and restarting solves this.
2W131L - USAF
#4 Rsterns
Rsterns
  • 943 posts
Posted 27 November 2011 - 07:18 PM
That is a bit odd. Never had one fail, but replaced it when I did my rebuild, don't know if the oil pump can get intermittent, or if it's sucking air somehow causing a lock, that clears when you turn off the car? When you did your pan, did you replace the O'ring on the pickup tube.
#5 Kevin.
    Dick Dabber
  • 5,447 posts
Posted 28 November 2011 - 10:46 PM
Yes. I actually cracked my oil pan so I made sure to buy all new gaskets. Got the kit off of FCP or something. I know 100% that I did it
2W131L - USAF
#6 KS855R
KS855R
    Captain Retard
  • 65 posts
Posted 30 November 2011 - 12:59 AM
Nothing to worry to much about unless its doing it a lot. As the guys said the O ring kit and PCV will help and most likely fix the problem. Before I bought my car the guy that owned it had the entire top end rebuilt because of the tick and it turned out to be the Orings which I found out after I got my hands on it. Not a bad deal for me though :-)
#7 Kevin.
    Dick Dabber
  • 5,447 posts
Posted 30 November 2011 - 01:01 AM
Well that's the thing... I already did the O-Rings and my PCV. Don't want to tear apart my motor so I'm not quite sure what's the next step
2W131L - USAF
#8 KS855R
KS855R
    Captain Retard
  • 65 posts
Posted 30 November 2011 - 01:07 AM
How often is it ticking? If its just cold starts and idles every so often I would not worry to much. Solid lifters tick when they get warn. The first thing I would try is a heavier weight oil, as for weight many people have different opinions. How many miles is on your engine? My friend has a BMW M3 that ticks loud! and it runs like a top.
#9 Kevin.
    Dick Dabber
  • 5,447 posts
Posted 30 November 2011 - 01:43 AM
motor probably has about 110k or so on it. It ticks randomly, I tried to figure out a pattern of when it acts up but it's too erratic. Engine runs strong no power issues so Im still lost
2W131L - USAF
#10 Kevin.
    Dick Dabber
  • 5,447 posts
Posted 19 January 2012 - 01:53 AM
Winter is upon me here in South Dakota and I'm seeing regular lows dipping into -20.
I'm contemplating switching to a 0w30 oil but I was thinking about using conventional oil....thoughts?
The car still clacks/ticks when cold btw
2W131L - USAF
#11 Keaton85
Keaton85
  • 6,439 posts
Posted 19 January 2012 - 02:02 AM
Why?
#12 Kevin.
    Dick Dabber
  • 5,447 posts
Posted 19 January 2012 - 02:07 AM
I've run zero weight oil in the past to help with cold starts.
2W131L - USAF
#13 Keaton85
Keaton85
  • 6,439 posts
Posted 19 January 2012 - 02:10 AM
but why dino? when you are trying to get a better flow...
#14 Kevin.
    Dick Dabber
  • 5,447 posts
Posted 19 January 2012 - 02:30 AM
So you're saying use full synthetic then
2W131L - USAF
#15 cruzer555
cruzer555
  • 88 posts
Posted 19 January 2012 - 02:33 AM
On cars my dad's owned that have done that, a few shorter OCIs (oil change intervals) took care of it... Idk if that'll work for you, maybe your already doing short OCIs, just sayin...
Also like pleasedelete says, keep running the synthetic. 0-30 synth has better flow that 0-30 dino.
My car: 1994 Volvo 855 NA - 137k miles - Auto :( - S80 T6 "Arrakis" wheels - 850R steering wheel
#16 Kevin.
    Dick Dabber
  • 5,447 posts
Posted 19 January 2012 - 02:35 AM
He last time I changed my oil I probably went almost 8k miles :(
Ill do an oil change at the end of the month and then a week after that to see if I notice any changes
2W131L - USAF
#17 Keaton85
Keaton85
  • 6,439 posts
Posted 19 January 2012 - 02:43 AM
I would try a 40 weight to see if that makes any difference. As for the winter weight, just keep in mind that the smaller the spread between the numbers the more longevity the oil will have. But at -20 haha, I think you might need the lowest you can get!!! wooooowww
#18 volvos70turbo99
volvos70turbo99
    Mrs. Brightside
  • 212 posts
  • Gender:Not Telling
Posted 19 January 2012 - 02:48 AM
try to throw some MMO, marvel mystery oil, i had a weird ticking noise and this quieted it down immediately, its thin and no it will not hurt your motor, replace 1 qt of oil on your next change, probably just a lifter.
1998 s70 glt t5 converted - 16t, white injectors, nxs mbc @ 14psi, k&n drop in filter, high flow cat, full 3in. exhaust, dp, hd wg, na tb, ipd turbo hoses, ard orange tune, stage 0 complete
#19 cruzer555
cruzer555
  • 88 posts
Posted 19 January 2012 - 02:57 AM
LOL I didn't mean that short! He did 4000 mile intervals and after a few the noise was gone. It stayed gone till we sold the car 150k miles later. The ticking really isn't a big deal, my car has it and I'm about to run my second 3k OCI, it should quiet down soon...
I'd run 0W-30 in the car for -20º and definitely stick with full synth. Also my car quiets itself in winter, it only clatters in summer when the oil is lighter...
IDK if I'd run any additives, not even MMO, but thats just me. Maybe if the short OCIs don't work, but considering your at 8000 miles on the oil I'd bet shorter OCIs would help...
#20 Keaton85
Keaton85
  • 6,439 posts
Posted 19 January 2012 - 03:32 AM
What the heck would short OCIs do for this?
Also tagged with lifters, oil, clacking
