Interior Sunroof Ring, How To Remove With Out Breaking?
Posted 28 November 2011 - 03:28 AM
thanks for all the help, I need to replace the sagging head liner.
Posted 28 November 2011 - 11:39 AM
Start from the front. The party that goes from driver side to passenger side near the mirror.
Open the sunroof
You slide it back while lifting it up. From the open sunroof side looking into the car. There are three little tabs that hook onto the trim.
If you tug on this trim and pull towards the rear of the car you can feel where the little tabs are that hook onto this trim. Iirc there is one inn the middle and one on each sides.
Once these are off, I bent the front enough to go into the car and and proceeded on the sides.
The rear I could not get off so I took the headliner and slide it back off the trim ring then I removed the trim ring.
Posted 28 November 2011 - 04:10 PM
Ive done about 20 and THAT is one of the MOST important steps...
Literally just ROLL it up and towards the center and it will come out with ease. Start with front and the rest is easy to see.
To bad your not local, could bang that out in under a minute. Ask Mattxxl, he was there
RobT5 FloridaVolvoCommunity Car Domain
Quote
Posted 28 November 2011 - 06:19 PM
Posted 29 November 2011 - 12:19 AM
Posted 29 November 2011 - 12:41 AM
Posted 29 November 2011 - 04:41 AM
Posted 29 November 2011 - 01:13 PM
fastwagonhawaii, on 29 November 2011 - 04:41 AM, said:
For an 850 you cannot get them
They are as I was told 2 years ago (on intergalactic back order)
and the 70 series at that time, there were only 20 left in the US...
Your best bet if you cannot get it out, is to hit up a s70 and remove that models trim as it is an upgrade
Id help you out, but the shipping would be hard... price to ship + the risk of it breaking. PM sent
Quote
Posted 29 November 2011 - 02:20 PM
16T/NXS MBC/Turbo Back/OBX V2 Strut Brace/Blueprinted, port &Polished head/N/A Cams/ARD Tuned/Samco I/C Hoses/Snabb Stuffz
Posted 29 November 2011 - 04:48 PM
Posted 30 November 2011 - 06:36 PM
Burn-E, on 29 November 2011 - 04:48 PM, said:
thanks again... this one really helped also.
