Use The Alarm Remote For Other Things?
Posted 29 November 2011 - 03:15 AM
I'm sure the volvo software has some good information but I can't access it at the moment... anyone familiar enough to pull out what I need? Or know off hand somehow?
I do have the wiring diagram but there isn't much, just pin numbers and colors.
Brian
'91 244 (project: never-gonna-be-finished-because-im-fucking-lazy)
'04 S60 2.5T (dd/old man car) | '92 245 | '02 C70 2.3HPT Coupe
Posted 29 November 2011 - 05:07 AM
it's 4/19, right under the board
some good stuff here
plug like
5--
4--
3--
2--
1--
I guess i'll see what's up with it
Brian
Posted 29 November 2011 - 06:05 AM
For the 5 pins, there will be: 12V constant, Ground, ACC Power (to disable when the car is on and to enable programming), Unlock, Lock.
Serge - 95 850 T5
Posted 29 November 2011 - 06:07 AM
its +/- and 3 going to the bigger unit RCQ RSS RDA -- is it even disabled when the car is on? I thought i've opened the trunk with it while sitting idling
i could really use some vadis information about the pins of that alarm system box "LOCK ALARM CONTROL" p/n 9472463 (denso)
Brian
Posted 29 November 2011 - 11:58 PM
ok now i see where you're going with that... but that's all done from the 2nd, bigger module based on what those 3 other pins are saying. I'm going to hook those guys up to the arduino and see what I'm working with....... once i figure out how to do that.
also still concerned at this "+9" .. do i really have to step it down from 12v?
Brian
Posted 30 November 2011 - 12:46 AM
to the lock module that runs a digital signal for various operations.
You might have some fun dealing with that, but it'd probably be easier to
just pick up a cheap remote module from the aftermarket security world.
There are a ton of keyless modules out there you can do plenty with.
Stuff like this may be a lot easier:
http://www.ebay.com/...=item415d27b1d3
Posted 30 November 2011 - 01:01 AM
Looks like you've got power,
ground and the other three
( these are for the pin #s on the lock module end...)
B16: Test signal for the receiver
A8: Signal, data from receiver, ID code
A9: Signal, signal strength from receiver
Posted 30 November 2011 - 01:20 AM
still, i think this is something I can work with...
BEJinFBK, on 30 November 2011 - 12:46 AM, said:
besides look at what i'd have to carry around as an alternative
Brian
Posted 30 November 2011 - 01:23 AM
Let us know what you find out.
Posted 09 December 2011 - 12:37 PM
I hooked everything up last night: computer power supply for power and then hooked up the other 3 wires to an Arduino to monitor the signals....
The new battery i thought I had for the remote was wrong kind (2032 vs 2016), so this is on hold for a couple days.
what I'm really curious about is... what will I see on those wires? i guess the arduino can really only see the voltage between 0 and 5... could it be anything else? pwm?
Brian
