Been Getting Harder To Start...now Dead
6 replies to this topic
#1 Meek
Meek
  • 556 posts
  • Crew:ECC
Posted 29 November 2011 - 02:36 PM
The 855 is been getting harder to start and now is dead. Battery or Alternator? Guess I should first have the battery tested, right? If it is good then it should be the alternator, correct? Just thinking out loud...
96 855R
00 Viggen
#2 cheapwagon
cheapwagon
  • 2,267 posts
  • Interests:LED Retro's
    VolvoSpeed
    Long walks on the beach
  • Crew:ECC
Posted 29 November 2011 - 03:29 PM
Fuel? Hard starting and then nothing was my Fuel pump.
View Postvolvo1911, on 26 March 2012 - 10:59 PM, said:
As for the cute little interest thing, i dont replace anything. Its called cleaning the system..
#3 the commissar!
the commissar!
  • 2,024 posts
  • Interests:interesting things...varies with temperature and altitude
  • Crew:ECC
Posted 29 November 2011 - 06:08 PM
Can you jump it off? If you can jump it it is not likely fuel related although you may have fuel issues contributing to the weak start...If it will jump, drive it to auto house to free test battery and alternator. check grounds to be sure they are clean. Check battery cables. Those are the high probability items...it gets harder from there...
1998 V70 T-5 -Auto / Pewter - Turbo-Tuner,18T, HD TCVw/ Hallman Pro MBC, custom 3" DP w/ Volvo 2.75" sport catback - both wrapped and coated, RIP, IPD aluminum intercooler, intake w/ K&N cone, R ex. manifold, , gasket matched & polished intake manifold w/ thermoblock spacer, n/a TB w/ 960 plate, Optima bluetop, MSD 6aD and blaster coil, IPD plug wires, IPD poly bushing, Koni FSD w/ Eibach springs, IPD sways 25mm x 25 mm, blue silicone vac, silicone coolant lines, custom intake tubes grill to turbo, skid plate, front lower brace, cherry turbo strut brace, HD endlinks, 302mm brakes, Zeitronix wide-band/data-logger, Walbro w/variable fpr. In process: Home grown HD Endlinks, Meth/H2O injection, greens, catch can, fully built 2.3.
Posted ImagePosted Image
#4 Guest_luke_jones_*
Guest_luke_jones_*
Posted 29 November 2011 - 07:31 PM
...thats what she said?
Seriously though, I've had a problem that sounds similar for a while now. Had my battery and alternator tested and all was fine....thought I had norrowed it down to my glove box light....but now that the cold weather is back, the problem has started to come back.
Good luck....if I come up with anything new on mine I'll be sure to post it.
#5 Keaton85
Keaton85
  • 6,439 posts
Posted 29 November 2011 - 09:17 PM
How are your plugs? Wires? Cap rotor... Mouse nest in the air filter. All the extremely basic things to check.
Fuel pressure at the rail
Battery age
Battery voltage resting (after 12hrs ish from full charge)
Battery voltage while running (if you can get it running)
Voltage off the alternator to test voltage drop to rule out cables.
Corrosion at the terminals
CEL if so what codes
Basics......
#6 Ihatespeedbumps
Ihatespeedbumps
    The Pied Piper
  • 3,479 posts
  • Gender:Not Telling
Posted 29 November 2011 - 10:53 PM
View Postplease delete, on 29 November 2011 - 09:17 PM, said:
Basics......
Hey buddy! long time no see?! Last I heard you were leaving the site for good?
98 S70 T5M
#7 Meek
Meek
  • 556 posts
  • Crew:ECC
Posted 30 November 2011 - 08:40 PM
Wow. So far, It actually seems like it was the battery. Old one tested 'Bad' at two shops. New one in and it starts right up. We'll see if this continues...
FWIW old battery was dated 2003.
96 855R
00 Viggen
