Grrr. Car Rolled Off Of The Jack
Posted 02 December 2011 - 08:14 PM
Posted 03 December 2011 - 01:10 AM
Posted 03 December 2011 - 01:44 AM
Check the rotor and hub to see if they are bent.
Volvospeed On Google+
Posted 03 December 2011 - 03:25 AM
Posted 03 December 2011 - 03:50 PM
Is it advisable to replace only one side of the rear rotors? I assume I'll have to do pads with the R&R, so I might as well do both sides.
Che' what PSA are you referring to?
Posted 03 December 2011 - 04:16 PM
This one
Posted 03 December 2011 - 04:47 PM
LOL! After that roll off, then the hassle of getting the jack back under the car, all done roadside in the dark, I bought a pair of those, plus a can of fix a flat... :-) Lesson learned.....This one
Posted 03 December 2011 - 05:20 PM
Sorry for the grim story, but it's an important one. I think of it every time I roll the jack under the car.
1998 V70 AWD 5-speed - 235k km - 2wd now. Good bevel gearbox and propshaft available!
Posted 03 December 2011 - 05:24 PM
Posted 03 December 2011 - 05:32 PM
Posted 03 December 2011 - 07:47 PM
You can get wheel chocks for free (or a buck or 2 if they actually charge you) at any pull-a-part from a Chevy truck. They come with a pair behind the seat. (part of the jack etc...) I have a couple sets.
Another fucking s70: with Lots of zip-ties, a power antenna, and a bitchin shift knob... the only mods that matter.
Posted 03 December 2011 - 07:51 PM
thanks for the tip on the locator pin. I'm going to make a visual inspection shortly. And I'm thinking of a better jack, too. Why volvo placed the jack point where it would lift the whole side of the car, not just one corner, is beyond me..
pretty sure they went to just the one in the middle when the 850 came out, if I remember correctly my 960 had 2 of those jack points, one right in front of the rear wheel and one closer to the front wheels .. but yeah it probably says in the manual dont get under the car with just that little jack in place .. should be common sense tho really .. but now these cars are starting to get driven by a generation raised by mtv reality shows
Former: 89 744 GLE 16V, 90 745 GLE 16V, 95 964, 94 854 Turbo, 01 S40 1.9T, 99 C70 HPT, 01 S60 T5, 07 VW GTI
Current: 98 V70 GLT - 157k, 02 Motor, 16T, ARD, etc. (DD), 97 854 GLT - 2xxk,(Under Construction)
Posted 03 December 2011 - 08:59 PM
#14
Posted 03 December 2011 - 09:19 PM
were you using the pos volvo jack I always wonder why they never had a lawsuit on those. I had the same thing happen three years ago. I also had the same wobble it was due to the wheel locator pin on rotor loosen up after dropping, re tighten and all was well.
They did recall them. Well not sure if it was a recall or replacement, but I did get a letter telling me to come get a new jack at one point. That said I use the OEM jack more than anything else. If I cannot get to my lift for whatever reason I will use the OEM jack to rotate the tires. Keep in mind I am never under the car, nor would I ever ben on any back. For everything else its lift or ramps.
#15
Posted 03 December 2011 - 09:28 PM
#16
Posted 03 December 2011 - 09:37 PM
http://www.ebay.com/...=item1e65dc7b07
Under 50 dollars shipped.
As for pads just inspect them. If they need replaced or are close than sure, but rear pads last a LONG time.
#17
Posted 03 December 2011 - 09:48 PM
#18
Posted 03 December 2011 - 10:15 PM
1999 S70 Base w/ Manual - "5 BANGER" - IPD Springs and Sways, HD Endlinks, Bilstein TC Struts, HD Shocks, OBX Strut Brace, Lots of Poly, Custom Exhaust, Amaltheas, Pioneer Double DIN
#19
Posted 04 December 2011 - 04:03 AM
I have always found the parking brake sufficient to hold the car when using the OEM jack... maybe I'm just lucky.
And foolhardy...I'm tempted to say stupid.
1998 C70 HPT M modified S70 T5A Emerald Green on Tan
#20
Posted 04 December 2011 - 04:49 AM
And we all know how reliable Volvo parking brakes can be...I have always found the parking brake sufficient to hold the car when using the OEM jack... maybe I'm just lucky.
