What A Difference Plugs Can Make
15 replies to this topic
#1 TRACStar
TRACStar
  • 2,417 posts
Posted 03 December 2011 - 02:42 AM
I've been chasing a rich (10.4-10.1) at WOT issue for longer than I care to remember, car had just always been that way.
Today I swapped out my plugs and figured I'd try a range colder..NGK BKR7E's....AFR's quickly drop to low 11's when going WOT then jump up and hold a rock steady 12.5-12.8. To say the car pulls harder is an understatement, its a totally different animal. What really has me intrigued is that when I ran a 13.7 quarter it was with a 10.2 AFR and the car felt the way it always did.
It never even occurred to me to try a colder plug, up until today the best plugs I used were OEM's, it ran better with them than any plug I tried before it so they're all I've run for the last couple years. And they never really looked burnt/fouled when changing. After today.......I'll never buy them again. :D
#2 vmaxx
vmaxx
  • 240 posts
Posted 06 December 2011 - 05:50 PM
I'll try these on my next change interval...thanks.
1997 850 T5..ARD Green/K&N Panel/IPD Parts/MSD/Silicone Everything
156MPH Sleeper...
#3 GltGreco
GltGreco
  • 1,254 posts
Posted 06 December 2011 - 06:09 PM
i still like my oem plugs, but i have been tempted to try the NGK BKR7E's i know a few people who run them and had a great response, but i can almost guarantee they will not last nearly as long as oem ones so i would keep an eye on that.
1998 S70 glt. T5 ECU, 16t, whites, japan manifold, turbo back exhaust,
ipd sparkplug wires, HD TCV, CBV, sways and springs, K&N filter
1999 Jeep Grand Cherokee Laredo, unstopable
#4 RobT5.
RobT5.
    Doctor Retardapus
  • 3,093 posts
  • Interests:We-mons
    Orange Soda
    Speeding
    Archery
    Cars
    Poking
    Your Mom
Posted 06 December 2011 - 06:25 PM
My old 850 liked to eat NGK's every 7k miles it was missfiring from fouled plugs. finally got tired of it and just bought bosch coppers. didnt eat them.
but yeah it ran better on the ngk's.
1998, S70 T5.
RobT5 FloridaVolvoCommunity Car Domain
Quote
optimus prime when i do get this whole project underway im totally gonna eat a sandwich in my engine bay
#5 gmsgltr
gmsgltr
  • 3,654 posts
Posted 06 December 2011 - 09:42 PM
gap?
- Greg - 96 Red/Tan 855 R 96k miles -
FOR SALE: Used 75k Miles OEM 16T Turbo/Angled/Ipd HD CBV - PM ME
#6 Snabb T5M
Snabb T5M
  • 10,331 posts
  • Interests:IU BASKETBALL; 1969 Roadrunners; Drag racing; rugby; traveling the world
Posted 06 December 2011 - 09:50 PM
I gap mine at like 0.025. And at roughly $2 a plug who cares if they only last 7k miles.
View Postgmsgltr, on 06 December 2011 - 09:42 PM, said:
gap?
Lee 1998 S70 T5M; 113K+ miles; IPD Stage III ECU; 18T turbo @18.5psi; Precision FMIC; R manifold; EST 3" DP; balanced crank with LGSpeed rods; 3 angle valve job; SPEC III clutch; ALL of Sconeman's T5M parts; KW2 coilovers; TurboSmart Eboost2 EBC ---13.605 @ 105.39 mph ---
#7 TRACStar
TRACStar
  • 2,417 posts
Posted 07 December 2011 - 03:39 AM
gap?
Gapped to .030 with a MSD 6A box.
I really don't mind if I have to change them every other oil change since their less than half the cost of OEM plugs. And with how much they leveled out my AFR's and smoothed out the power curve, longevity is a small price to pay IMO.
#8 vmaxx
vmaxx
  • 240 posts
Posted 09 December 2011 - 01:39 AM
I got the ipd MSD coil upgrade, is it the same as the 6A so I can gap the NGKs at .30?
UPDATE: I read the package and it says Blaster SS so i'm guessing it's not a 6A...anyyone have an idea what gap is recommended for NGKs?
Edited by vmaxx, 09 December 2011 - 02:05 AM.
156MPH Sleeper...
#9 Hippicus Rebuildacus
    I Love To Pound Ash
  • 2,573 posts
  • Interests:doin a line of blow off a stippers a$$, Minikitti, Volvos, Architecture, $$$
Posted 09 December 2011 - 02:11 AM
I have run BKR7E for about a year and a half and they do last a long time but you have to re-gap them more often than other plugs. I save about a years worth of used plugs to see any kind of pattern as well and I havent seen any issues other than the occasional higher than normal suitting. Obviously going 1 heat range isnt going to cause issues in regards to fouling but it DOES let your plug become fouled sooner with normal driving / idling. It is a colder plug which means it must run just a tiny bit harder to keep them at the same optimal temperature. If you don't push push your car to the point you feel you need a heat range colder plug in order to eliminate a misfire you could just stick with 6's instead of 7's. If you do a lot of idling or heavy traffic driving or just drive like an old lady never getting past like 3K rpm you will foul the plugs out faster resulting in a misfire or just poorer performance.
I no longer run BKR7E's but I never had an issue with them @ .026 - .028 gap with a MSD Blaster Coil.
My plugs come out Every other oil change so every 6K miles they are back out the car, not to be re-gapped either they just come out & new ones go in. and as someone already stated for under $2 a plug I could care less and it gives me piece of mind.
.030 = stock
anything that people post below that are either trying to compensate for a miss fire or the fact that they are pushing much more air than stock. Obviously as upgrades increase you are pushing more air into the motor and having the ability to blow out the spark like a candle in the wind. a Misfire doesnt always mean that you have to lower your gap as you could have some failing or older ignition components. I thought I had a miss fire after about 3k miles on a set of plugs but I have never had an issue before so I decided to look at everything from the plug back to the coil, turns out it was a 2 year old cap & rotor. The cap was decent but the rotor's saw tooth that rotates around and makes contact with the cap nodes was completely worn down to the point the spark had to jump more than normal to send its current. This reduced the strength of the spark resulting in a weaker ignition in the chamber.
When you upgrade things such as your ignition components you usually will wear out other ignition related items sooner as well. Stronger hotter spark from the ignition coil wears on the cap/rotor as well as the plugs.
Beiber: kurt i got with a cougar last weekend
Dr.PorkenheimersBonerJuice: no you didnt kev, you jacked it to pictures of teen mom. that isnt cougar
SHIT IM SELLIN ; SHIT YOU BUYIN. DONT BE A BITCH ; CLICK IT
#10 dimka18
dimka18
  • 395 posts
Posted 09 December 2011 - 04:07 AM
Im running those NGKs in my R as of today, and at 17psi i can feel it misfiring. Gapped at .026. Next time changing cap and rotor.
1996 Volvo 855R, M56H, 16T, 3in DP, Custom exhaust, Tune, 16psi mbc. More to come
Posted ImagePosted Image
#11 the commissar!
the commissar!
  • 2,024 posts
  • Interests:interesting things...varies with temperature and altitude
  • Crew:ECC
Posted 09 December 2011 - 01:39 PM
On gap: Start with stock and adjust if you must...
On ignition components: Blaster SS is a coil and a 6A is an ignition controller box...both made by MSD. They do different things as parts of the total ignition system. The coil converts low voltage ~12v used by most of your car, to high voltage (tens of thousands) necessary to make the plugs have enough energy to spark. An ignition controller actually controls the timing of the firing of the plugs in conjunction with the distributor/rotor.
1998 V70 T-5 -Auto / Pewter - Turbo-Tuner,18T, HD TCVw/ Hallman Pro MBC, custom 3" DP w/ Volvo 2.75" sport catback - both wrapped and coated, RIP, IPD aluminum intercooler, intake w/ K&N cone, R ex. manifold, , gasket matched & polished intake manifold w/ thermoblock spacer, n/a TB w/ 960 plate, Optima bluetop, MSD 6aD and blaster coil, IPD plug wires, IPD poly bushing, Koni FSD w/ Eibach springs, IPD sways 25mm x 25 mm, blue silicone vac, silicone coolant lines, custom intake tubes grill to turbo, skid plate, front lower brace, cherry turbo strut brace, HD endlinks, 302mm brakes, Zeitronix wide-band/data-logger, Walbro w/variable fpr. In process: Home grown HD Endlinks, Meth/H2O injection, greens, catch can, fully built 2.3.
#12 boxpin
boxpin
  • 835 posts
Posted 09 December 2011 - 02:20 PM
Watch this video, it will explain what the 6a does. Talking to Hussein, he said that it works great but goes through cap and rotors. COP (coil on plug) may be the solution.
http://www.msdvideos...il.php?mId=8568
13.7 @ 99 Automagic Posted Image 13.8 @ 104 Manual
1995 855M - Quaife, 18T, ARD Blue, Meth, 3" catless, FMIC, N/A(cams & TB), Scone, H&R, Bilstein
#13 the commissar!
the commissar!
  • 2,024 posts
  • Crew:ECC
Posted 09 December 2011 - 03:09 PM
:rolleyes: at the sales pitch in that video...
I have been running the 6a digital and have not had that problem (yet)...I've got about 18,000 miles on my 6aD. I'm sure I don't run my car as hard as many of you but occasionally I step out...When I do I don't want spark blowout causing misfires.
#14 boxpin
boxpin
  • 835 posts
Posted 09 December 2011 - 05:14 PM
Agreed, they are a bit giddy over it.
#15 vmaxx
vmaxx
  • 240 posts
Posted 09 December 2011 - 05:31 PM
hmm..thanks for the video!
My cap and rotor is a year old Bosch unit, i'll have to replace/upgrade my knock sensors,MAF Sensor, fuel pressure regulator, 98+ T5/R injectors, NGK BK7RE plugs to hopefully, completely, cure the sporadic stutter mid to high rpm.
Was good today, 5% of the time it stutters so i'll get those parts cheapest to most expensive soooon,,,,
Oh yeah, stock gap is .28 correct?
Edited by vmaxx, 09 December 2011 - 05:32 PM.
156MPH Sleeper...
#16 vmaxx
vmaxx
  • 240 posts
Posted 09 December 2011 - 06:28 PM
Thanks for the explanation Commissar!!
P.S. I WAS gonna say "thanks Commie!" but then I realized....
Edited by vmaxx, 09 December 2011 - 06:29 PM.
156MPH Sleeper...
