Cam Seals Leaking Again
Started by dublin14, Dec 03 2011 10:58 PM
8 replies to this topic
Posted 03 December 2011 - 10:58 PM
My motor has about 2000 miles on it now and the first set of OEM seals leaked. Put in a new set again last night, and leaking again.. RTV around the seals next? Any Imput would help.
Posted 03 December 2011 - 11:36 PM
Make sure there's no marring or scratches on the sealing surfaces?
'95 854 T5M 175k - Koni Yellows, IPD Strut Brace, IPD CAI, IPD 25mm front sway, IPD Poly Upper, M56H, NA TB+Mani, Japanifold, OBX exhaust w/ angled housing, IPD springs, 2.25" Plumbed FMIC, 18T, ARD Blue
Posted 03 December 2011 - 11:46 PM
Front or rear?
+1 on making sure the aluminum wasn't nicked upon seal removal.
98 S70 T5M
Posted 04 December 2011 - 05:57 AM
This is what I found upon removing mine. No wonder why the damn car always leaked.
1998 S70 T5
(315): Good ideas don't start with we have a bottle of vodka
Posted 04 December 2011 - 01:31 PM
Its clean and no issues there. Maybe RTV the seals and try again
Posted 05 December 2011 - 12:34 PM
Just to make sure on you meaning of "OEM"--genuine Volvo, not OEM-grade? I replaced mine with one of the common "OEM" ones--think they were Elring--and they didn't last long. Better to use the factory ones here, if you didn't.
1996 Volvo 850 Turbo Sedan, 127k
N. Virginia
N. Virginia
Posted 05 December 2011 - 01:03 PM
Volvo OEM and then tried aftermarket. Both leak.
Posted 05 December 2011 - 01:26 PM
I bought cam seals from napa when I first got my 850, lasted 60k miles and still looked good when we ripped apart the engine for parts for the s70
Try those, if nothing else its only 14$ down the hole.
RobT5 FloridaVolvoCommunity Car Domain
Quote
optimus prime when i do get this whole project underway im totally gonna eat a sandwich in my engine bay
Posted 05 December 2011 - 04:23 PM
See my reply in your other thread. Don't use a screwdriver to install them. Don't use any RTV. Use wheel bearing grease on the inner lip.
