It's a lot more blue then the photo, worked out well I think! Now I just need to start working on the rest of the dash, I will likely just make all the T4 LEDs since they are way to expensive online!
Hu-803 Led Install Complete!
Posted 04 December 2011 - 09:33 PM
Posted 04 December 2011 - 10:00 PM
Posted 05 December 2011 - 05:17 PM
The display need to be desoldered and it's a major PITA unless you have the skills and tools to do it. You have to desolder about 50ish pins and then bend the display over on the other pins to get to the 4 lights behind it.
Posted 05 December 2011 - 05:53 PM
Posted 05 December 2011 - 09:23 PM
Serge - 95 850 T5
Posted 05 December 2011 - 09:28 PM
Serge, on 05 December 2011 - 09:23 PM, said:
Climate control on a 01-04 or on a 98-00?
I'm going to try and add two lights per location to get a slightly more even output so I can take photos then. It's really simple other then the display.
Posted 09 December 2011 - 05:47 PM
http://volvospeed.co...l-led-solution/
The OSRAM LEDs are awesome. Great even light with plenty of output. Not to mention it's a quality brand that will last.
Serge - 95 850 T5
Posted 10 December 2011 - 01:54 AM
Much cheaper to make your own then buy the $5 dollar pre made units.
Posted 10 December 2011 - 02:07 AM
I am going to do a bunch of straight and square boards of 4 PLCC2s since this keeps the wattage requirements down for the resistor. Then I can make a bulk lot of them without much custom work. Afterwards place them in the areas that need to be lit.
I'm getting a voltage output of 13.2V so running the LEDs at 3.2v would allow me to use just a 20 or so Ohm resistor at 1/8watts.
