I have a 99 C70 and notice that whenever I use the key to unlock the door instead of the fob, my alarm goes off. When I lock the car, I have tried all 3 ways and still the same result:
1. lock with inside button on door
2. lock with key
3. lock with keyfob
I have only 1 keyfob, so whenever I use a spare I have to quickly hop in and turn the ignition on to shut off the alarm. Does anybody have any ideas?
Alarm Sounds Unless I Use Keyfob To Unlock
Started by toasty, Dec 06 2011 03:34 AM
8 replies to this topic
Posted 06 December 2011 - 03:34 AM
1999 C70 T5M
Looking for a 2005 CL65 AMG
Posted 06 December 2011 - 10:04 PM
Get another keyfob.... And stop unlocking your door with your key! Simple
Posted 06 December 2011 - 10:31 PM
Possibly the unlock switch in the door lock.
When you turn the key to "unlock" a second time,
does the other door unlock?
Posted 07 December 2011 - 02:05 AM
No the passenger door doesnt unlock and the interior lights do not go on neither. Does this mean I need a new door lock? cuz thats another $200 to volvo dealer for bad quality locks, already had to do the passenger side
1999 C70 T5M
Posted 07 December 2011 - 02:19 AM
Pretty common to get a used door lock actuator assembly and replace your broken one. or if your handy replace/clean the micro switch.
OR, stop using the key.
Posted 07 December 2011 - 05:02 AM
if you are able to open the door when the door pin is in the locked position, it needs the door lock actuator. mine crapped out on the passenger side.
///T5
Posted 07 December 2011 - 05:31 AM
are c70 door lock actuators different than s/v70?
1999 C70 T5M
Posted 09 December 2011 - 09:55 PM
But swapping in a known good may be easier.
And I'd shop around for a better price on a new one.
A J/Y replacement will only last so long...
