S-80 Control Arm Replacement
#1 TLsdad
TLsdad
  • 45 posts
Posted 06 December 2011 - 02:12 PM
Does the engine have to be lifted in order to get the inner control arm bolts out through the frame or can you tilt the bolt once its unscrewed from the control arm? The haynes manual says that on the right control arm requires the engine to be lifted.. I looked at both sides and I can get a box wrench on all four bolt heads to remove them... Thanks
2001 S80 2.9l non-turbo, 1991 240 GL, 1993 850 T5R, 2006 S-40 T5R
#2 Keaton85
Keaton85
  • 6,439 posts
Posted 06 December 2011 - 10:00 PM
You can unbolt little by little to get the control arm off and leave the bolt installed. Then just reinstall the new control arm.
#3 chlacrosse14
chlacrosse14
  • 35 posts
Posted 07 December 2011 - 11:10 PM
I have heard you need to lift the engine, but if you end up being able to get the control arms off without lifting the engine please let me know. I'll probably be doing the control arms on my S80 in the near future.
[center]Posted Image
#4 burnout8488
burnout8488
  • 172 posts
  • Interests:Daily Volvo Repairs
Posted 10 December 2011 - 06:57 AM
17mm one of these:
Worked great on my S70 AWD for those pesky bolts right next to the oil filter housing. The flex head is key.
'99 S70 AWD except not
2.4+15g/Rmani/Snabb Intake/ARD Green
