Removed Front Anti Roll Bar
Posted 06 December 2011 - 11:00 PM
The result so far is much better traction and far less wheelspin in all conditions - this was my aim. I feared it would roll all over the place and be scarily tail happy but up to now it seems relatively tame. It is noticeably more settled on rough surfaces and doesn't want to cock a wheel anymore on speed bumps taken at an angle.
With the bar attached I get a lot of traction loss at any front/rear damper settings from full hard to full soft. For sensible dive and roll control I was running the front dampers at 15 clicks (of 30) from full hard with the bar - less than 10 from full hard gets too jittery on my local roads to be enjoyable. At the same 15 from hard setting with the bar disconnected there was noticeably more front roll so I notched it up 4 clicks. Now very little roll (still more than with bar attached) but much more settled.
The traction difference has made me smile where previously I was cursing not getting power down in anything below 4th. My brain tells me this is probably illegal, may catch me out in the wet with snap oversteer and just sounds plain wrong. My experience of it is that the ride is comfier even at harder damper settings, the car pulls out of corners and in a straight line much better, is more composed overall and even with some fairly aggressive provocation the back end stays put. It "feels right".
I have bought a used 2001 23mm front bar off a 2.0t S60 to swap for the IPD one but even so I don't want to fit it. The IPD bar (25mm) is 40% stiffer than the stock one so I will get better traction if I swap but I think that with the stiffness of coilovers up front it is really driveable without. The IPD front bar with my set up is far from how I want it - I can't believe I drove the car with just the front one for ages, it must have been awful.
It has been firmly suggested I should fit the stock bar so in time that's what I'll do but I'd be interested in anybodys comments as we all rush out and buy these things without thinking sometimes (I did). Lets face it my HIDs/Carbotechs are not strictly legal but that doesn't make them dangerous - that's how I'm viewing the disconnected roll bar in the context of good roll control with coilovers..
Interesting link on the effect of roll bar thickness on stiffness (stiffness is proportional to thickness to the power 4).
http://www.balancemo.../Whiteline.html
eg: 23mm 23*23*23*23=279841
25mm 25*25*25*25=390625
so 390625/279841~1.4 ie: 40% stiffer.
Posted 07 December 2011 - 10:28 PM
When mine was disconnected (read broken endlinks), sure felt better go around roundabouts, but i didn't like the roll at 60+ speeds, and also felt a bit more unstable.
http://narancsphotoblog.blogspot.com
Posted 08 December 2011 - 12:04 AM
Jardon, I've been thinking about doing something similar. We all know how easy it is to have the front end wash out into corners on these cars. I feel that roll stiffness should be achieved through suspension geometry and springs. Roll bars have always struck me as being a band-aid solution that may leave some undesirable traits in the handling. Have you tried a stiffer rear bar with no front bar?
Posted 08 December 2011 - 04:22 AM
Posted 08 December 2011 - 05:45 AM
Posted 08 December 2011 - 06:06 AM
ipd sparkplug wires, HD TCV, CBV, sways and springs, K&N filter
1999 Jeep Grand Cherokee Laredo, unstopable
Posted 08 December 2011 - 07:28 PM
My gsr handled amazing.
Jcviggen was driving his car with the oem front, and 25mm rear.
Once I saved enough money, I'll overhaul the suspension of my car, ans the sway bars will be oem front, and 23mm ipd one.
Cheers.
Posted 08 December 2011 - 07:36 PM
Jardon - Did you keep the oem front sway?
Posted 08 December 2011 - 07:50 PM
FOR SALE: Used 75k Miles OEM 16T Turbo/Angled/Ipd HD CBV - PM ME
Posted 08 December 2011 - 08:06 PM
gmsgltr, on 08 December 2011 - 07:50 PM, said:
Me too, but I guess it really depends on how you drive it.
Want more rear end rotation you gotta have more bar in the back than the front...
in the Saab world, most tuners only uprate the rear bar...I have a lovely big rear bar on my Viggen and stock on front...works great on that thing.
Posted 09 December 2011 - 06:50 AM
cornellfsae.com
borgwarnerboosted.com
Posted 11 December 2011 - 03:47 PM
My pride and Joy -------------------------------------Volvo Rat------------------------------------ 98' 874 T5
No power Steering, Bride Bucket Seats, M56H swapped, FMIC, OBX exhaust,
All digital gauges, Koni Yellows, Ipd Sport springs, Rebuilt head, N/A Cams
Posted 12 December 2011 - 04:29 AM
#14
Posted 12 December 2011 - 04:40 AM
Volvospeed On Google+
#15
Posted 09 January 2012 - 07:44 PM
I don't notice any issue with roll or sloppy turn in but I have yet to get on track with it - the current set up is ideal for the prevailing conditions which tend to limit both traction and outright speed anyway.
Somebody asked about the rear - it's a 22mm IPD bar (I'm not sure what the stock one is). I have a stock front bar that may go on if I need it in the summer but I would like a stiffer rear bar - can I get a 25mm rear bar for a 2002 V70?
I have no oversteer issues and I don't want any - I suspect this has a lot to do with relatively stiff front coilovers and conservative toe settings (toe in front and rear). I run 1.5 degrees of negative camber front and rear.
#16
Posted 09 January 2012 - 07:50 PM
#17
Posted 09 January 2012 - 09:12 PM
As stock it was Front - 23mm, Rear - 21mm.
IPD was Front 25mm, Rear - 22mm but I didn't like it.
I currently run Front - NIL, Rear - 22mm.
I don't fancy running the front stock 23mm bar with the rear IPD 22mm bar but I have found this: http://www.ultraraci...ars.asp?ID=3811. It's a 25mm rear bar and I am very tempted as it may complement the stock front bar nicely.
#18
Posted 09 January 2012 - 09:51 PM
I've driven lifted 4x4's on the street with no sway bars. It can be a scary thing. lol.
855 Turbo Automagic :: T3/T4E .60 + E85 = fun!
4 gears, 5 cylinders, 7 seats...13 seconds.
#19
Posted 09 January 2012 - 10:26 PM
850wagonT5, on 09 January 2012 - 09:51 PM, said:
With an appropriate spring rate in the front, which it sounds like Jardon has, I'm not sure if I would agree with this sentiment.
Besides, if you can put the power down earlier, carrying a slightly slower speed through the apex isn't the end of the world.
