There's a 2001 s60 at the yard as of yesterday. No clue what trim. What's the difference between 2.4, 2.4t, or t5 motor? I would research more myself but im mobile.
2001 Rn Motor
Started by FINN, Dec 07 2011 12:56 AM
4 replies to this topic
Posted 07 December 2011 - 06:47 AM
To summarize:
all '01 engines had VVT, NA had VVT on intake, turbos had VVT on exhaust. Otherwise, the heads were the same, same valves, springs, etc. only cams and VVT were different.
2.4 is 83 mm bore, 90 mm stroke around 10:1 compression
2.4T is LPT, 83 mm bore, 90 mm stroke, compression 9:1
2.3 is HPT (T5) 81 mm bore, 90 mm stroke, compression 8.5:1
Engine has serial number and engine type on decal on front engine cover (passenger side) and it tells you what engine it is, if ther is a "T" in the engine type, it is turbo, but
B5244S in NA
B5244T is LPT turbo
B5234T3 is HPT (T5) turbo
B5244S in NA
B5244T is LPT turbo
2001 S60 T5 Manual Black/Oak 222K miles; Ultra Racing front, rear braces, iPD front & Evolve rear sway bars, XC90 brakes, gauges
1997 854 GLT NA Manual 192K - son; 1995 854 NA Auto 240K - daughter
Posted 07 December 2011 - 02:58 PM
Keep in mind that the longer (stronger) rods and shorter pistons did not show up until '02. Try to get one of those unless you plan on replacing them anyway.
Posted 07 December 2011 - 06:55 PM
Thanks guys. Motor was already gone
-Petri (Val)
