2000 S70 Timing Marks
Posted 12 December 2011 - 03:10 PM
any one have any tips for finding this damn thing before i lose any more hair!?!?!?
2000 S70 GLT... kicked the timing belt... getting tradded in when its back together...
2001 Lightning 400/480 on 9lbs of boost... unstock and sold
Posted 12 December 2011 - 03:22 PM
You might need to talk to your eye doctor.
To find the marks on the crank it's easier if you remove the crank pulley, but if you can't then you'll looking for the notch on the oil pump to be between the two notches at the back of the crank gear.
disregard the info on the camshafts, but the picture for the crankshaft will give you a clear idea of what the timing marks should look like.
http://volvospeed.co...elt_change.html
Posted 12 December 2011 - 03:33 PM
i have the balancer off. only mark i can actually see is the big pointer on the hub to the balancer. and i have it lined up with the mark on the oil pump.
Posted 13 December 2011 - 01:25 PM
buddy of mine in Sweden sent me the stuff the dealer uses and the mark is being shown in the actual pulley itself, after checking mine last night i dont have a mark in mine. a how to i had said the mark is about the size of a needle. is this true?
Posted 13 December 2011 - 05:41 PM
Posted 15 December 2011 - 03:33 AM
http://volvospeed.co...these-see-pixs/
DO you see dots on your cams like the ones on mine?
http://s25.photobuck...lvo 95 850 GLT/
80K+ miles on 2nd motor, got it for $500 bucks!!! Now w 6k HIDs/17" Canistos..
Posted 15 December 2011 - 01:07 PM
mine didnt have dots...
mine had dash marks like these
the crank is the one i cant find. i actually got some free time again tonight so im going to go back out and start working on it again
Posted 15 December 2011 - 01:12 PM
Posted 16 December 2011 - 12:27 AM
Posted 19 December 2011 - 12:38 PM
Posted 20 December 2011 - 12:55 AM
Posted 20 December 2011 - 02:18 PM
please delete, on 20 December 2011 - 12:55 AM, said:
i replaced the head already with a head that didnt have any bent valves.
i have the crank pulley timing mark aligned with the mark on the oil pump that didnt get removed
i have the intake cam timing mark aligned with the mark in the cover
i have tried the exhaust cam timed with the VVT pulley at its free state and the mark aligned and the mark aligned with the slack out of the VVT pulley
both end with the same result. about a 1/4 turn of the crank and the motor stops.
ive tried it with the cuts on the driver side of the cams being flat ( per 850 directions i had) and the motor turns over fine but with it like that the exhaust cam timing mark is WAY off. but the intake is correct
Posted 21 December 2011 - 02:27 AM
SRTthis, on 20 December 2011 - 02:18 PM, said:
Was the VVT hub/gear assy. removed from the exhaust camshaft at any time during the head removal or installation process? If so then the cams MUST be locked from the rear when the VVT hub is re-installed. That's the only way to get it installed properly.
#14
Posted 21 December 2011 - 01:09 PM
Volvo5.0, on 21 December 2011 - 02:27 AM, said:
sick motor in your car. i know that intake from a mile away!
#15
Posted 21 December 2011 - 02:52 PM
#16
Posted 21 December 2011 - 02:57 PM
#17
Posted 22 December 2011 - 02:10 AM
#18
Posted 22 December 2011 - 03:50 PM
Gilhuly, on 22 December 2011 - 02:10 AM, said:
thats how i have it sitting right now with the exhaust cam slot parallel with the deck. but my VVT hub automatically pulls counter clock. so the exhaust cam mark wont line up at all?
#19
Posted 02 January 2012 - 02:51 PM
#20
Posted 02 January 2012 - 03:38 PM
SRTthis, on 02 January 2012 - 02:51 PM, said:
This is what the cams should look like when viewed from the rear. Make sure the slots are offset as shown or you could be 180 out....
