Hard Start After Fuel Fill Up
6 replies to this topic
#1 cw4dug
cw4dug
  • 2 posts
Posted 13 December 2011 - 09:51 PM
My wifes 99 C70 starts hard immediatly after fillingthe tank. You have to let it crank for a bit and then it eventually starts. Once its starts you have no problem starting untill you fill the tank again.??????
#2 Dan A
Dan A
    Old Man Crew Pledge Pres.
  • 1,809 posts
Posted 13 December 2011 - 11:08 PM
Any CEL's?
99 V70R
98 V70 GLT
#3 kalvin
  • 1,645 posts
  • Interests:Pirates, Cars, Random Acts of Awesome
Posted 13 December 2011 - 11:15 PM
Mine does this as well. No CELs and the runs fine and starts normally after just as the op describes.
96 855T - (NVRGNGVUUP)
ARD Green M4.4 @ 17psi, 18x8 Borbet Odysseus, "Modified" D2 Racing Coilovers, Cherry Turbos Strut Brace, iPd Sways 25/25, Fujita Intake, Snabb Intake Pipe, NA TB+960 plate, NA Intake Manifold, iPd Phenolic Intake Spacer, 2.5in Magnaflow Catback
#4 DaveOH
DaveOH
  • 21 posts
Posted 30 December 2011 - 02:29 AM
Had the same problem on a 2000 V70. The problem was a faulty EVAP purge valve ($36.72 at IPD). The valve is located on the right side of the radiator fan housing near the battery. Very simple to replace.
Attached File  Evap Purge Valve.jpg   95.02K   7 downloads
<b>Dave </b>
Columbus, Ohio
1999 Volvo C70 (155,000 miles), 1998 Volvo XC70 (140,000), 2000 Volvo V70 (160,000)
#5 DaveOH
DaveOH
  • 21 posts
Posted 30 December 2011 - 02:38 AM
[attachment=8634:C70 EVAP Purge.JPGHere is a picture of the EVAP purge valve on a 1999 C70.
<b>Dave </b>
Columbus, Ohio
#6 kalvin
  • 1,645 posts
Posted 30 December 2011 - 02:39 AM
Cool! Thanks for the reply!
#7 pcguru000
pcguru000
  • 537 posts
Posted 03 January 2012 - 01:12 AM
it would probably through a cel but gas cap leaking perhaps? and maybe the evap system is not handling it well?
