The markings to properly align cams before removing timing belt on an 06 xc90 2.5T. Thanks.
Exhaust cam:
http://i25.photobuck.../Picture002.jpg
Intake cam:
http://i25.photobuck.../Picture001.jpg
Thanks..just want to make sure before I go and change the timing belt on my xc.
Are These? See Pixs...
Started by xallenx, Dec 15 2011 02:44 AM
6 replies to this topic
Posted 15 December 2011 - 02:44 AM
95 850 GLT & 06 XC90 FW 87K+
http://s25.photobuck...lvo 95 850 GLT/
80K+ miles on 2nd motor, got it for $500 bucks!!! Now w 6k HIDs/17" Canistos..
Posted 15 December 2011 - 02:56 AM
I can't tell what angle your taking the pictures from. Plus there is no reference with the upper timing cover.
98 S70 T5M
Posted 15 December 2011 - 03:08 AM
you are looking at both cams straight on. So the top is the top and the bottom is the bottom of the cam sprockets. It's not aligned to the upper timing cover. Just wanting to find out if these are the markings.
Posted 15 December 2011 - 03:36 AM
Align the crank and the cams will fallow....
Posted 15 December 2011 - 03:39 AM
Where is the crank marking located? Is it a line, a dot, a notch?
Posted 15 December 2011 - 03:48 AM
a notch..those are the right marks on the first pic but cant tell on the second..when aligning the crank you may need to turn it a few time until both cam marks line up..
some decent pics of it on this thread..
http://volvospeed.co..._1#entry2046468
good luck man..
good luck man..
2002 s40. 107,xxx.
Posted 15 December 2011 - 04:11 AM
good luck man..
good luck man..
OH!!! now I see. On the crank are notches. THANKS!
