Running standard BBK setup: 928 calipers, S60 rotors, IPD stainless lines. Question is: what is the consensus here on brake line length for these calipers. The IPD lines seem short, they get stretched as the steering gets closer to full lock, not an issue on the road, but seems like there might be trouble eventually from stresses from parking etc. Any one have a recommendation for where to get longer lines made, and how long? Thanks for looking.
Longer Ft. Brake Lines After Porsche Bbk?
Started by Ruhl98t5wag, Dec 15 2011 01:40 PM
8 replies to this topic
Posted 15 December 2011 - 02:31 PM
Something doesn't sound right. I'm running the IPD BBK kit, which includes the SS lines and have had no such issues.
'98 V70 T5 (Auto) At 280,000 fresh rebuild with port and polish ;Cryo treated everything, IPD Stage III w/ IPD Intercooler and TME cat back exhaust,Koni FSD/ Eibach springs, IPD sways F/R, IPD HDEndlinks, IPD BBK; Slide Show of build: http://rides.webshot...563883893OGxoym '96 965 A sweat find with 30K miles on it! http://rides.webshot...myd?vhost=rides
Posted 15 December 2011 - 02:38 PM
98 T-5 Wag 135K, CJ 3"DP, IPD ECU, TME cat back, Ateck intercooler, custom RIP, CDA, IPD sways, Tomtbone, Koni, H&R, 928/ 60R BBK. 99 S-70M 105K, stock. 93 960 wagon, 130K, trailer hitch...
Posted 15 December 2011 - 05:53 PM
I used the EST lines, but only because I had bought them prior to buying the BBK from IPD. They are exactly the same length, and are fine. If you are checking this with the car jacked up, they will definitely appear too short.
Posted 18 December 2011 - 09:08 PM
Same setup with IPD s/s lines... no problems here.
Check your car on an alignment rack so you can turn the front wheels lock to lock.
Nick Choy
President & Founder, Oregon Volvo Tuners
覧覧覧覧覧覧覧覧覧覧覧覧覧
'98 V70R AWD, '89 245DL, '71 142e, '67 122s
覧覧覧覧覧覧覧覧覧覧覧覧覧
Posted 18 December 2011 - 09:20 PM
Posted 20 December 2011 - 09:21 PM
Had the same issue, just ended up relocating the brake line attachment point on the inside fender a little lower and the problem was solved.
