I have a 02 S60 AWD and when I'm backing out of parking spots its like the rear brakes are applying and brings me to a stop.
It has DSTC.
Has anybody seen or heard of what is causing this?
Thanks in advance.
S60 Awd Cannot Back Up And Turn.
Started by Canadianplat855, Dec 17 2011 01:07 PM
Posted 17 December 2011 - 01:07 PM
Posted 17 December 2011 - 02:49 PM
I had the same problem in my '02 S60 AWD. The car would bind up in reverse when turning out of parking spots. I replaced the angle gear with a low mileage unit and it now backs up freely even when turned full lock. The angle gear had a slight whine to it and had been seeping fluid for a few years, when I took it apart it showed slight discoloration/heat on the edges of ring and pinion gears.
Hope that helps!
Hope that helps!
'02 S60 2.4T AWD - RICA Stage 2 ECU, 16T Turbo, R Manifold, Custom FMIC,Cone Filter, Snaab pipe, OBX DP, EST Non-Resonated 'R' Catback, OEM Sport Kit, +05 Lights, Eibachs, Bilstein Sports, IPD R Track Spec Sways & Links
'98 V70 AWD - Needs work, will be awesome.
Posted 18 December 2011 - 03:03 AM
Hope that helps!
Hope that helps!
Awesome sounds just like my car. Did it seem like the brake where applying?
