98 Awd Clunking After New Driveshaft Install?
Posted 18 December 2011 - 04:26 PM
Looking for ideas on what's broken.
1998 V70R, 203k, black: EST duals, IPD sways+HDlinks, 302 brakes, ss lines+AteSB, ABMs+4200HID, K&N filter, Propus Cs, Eclipse DVD/nav AND 1991 740 Turbo wagon, mystery mileage, red: stock utility beater with crazy sound system. Sold: 1995 T-5R sedan
Posted 18 December 2011 - 04:33 PM
Posted 18 December 2011 - 06:52 PM
okoye, on 18 December 2011 - 04:33 PM, said:
I followed Volvo shop manual installation procedure and torques, using all new bolts of equal length.
Which bearings?
Posted 18 December 2011 - 11:47 PM
Me: "Yea."
Posted 29 December 2011 - 02:53 AM
I followed the VADIS AWD VC troubleshooting procedure:
"Ensure that the viscous unit remains at room temperature (it was about 45 F outside but best I can do).
A7700344
– Raise the left or right-hand front wheel so that it ro- tates freely. The other wheels must be in contact with the ground.
– Select neutral.
– Position a torque wrench horizontally as illustrated (basically attach it to the big axle nut and position the wrench so that it's parallel to the ground with the handle pointing in the direction of the front of the car. Read the torque value.
– Turn the torque wrench half a turn (180) clockwise with even torque for 25 seconds.
– The torque must be GREATER than 50 Nm ( 37 lb ft) during the entire turn.
The test method assumes that all the other components included in the system function correctly. If the torque is below 50 Nm (37 lb ft), the viscous coupling is outside the specification and/or damaged."
What if the torque seems REALLY high, as in I can't turn the wheel more than about 10 degrees? It feels like VC is totally locked up. So I slid under the car to check the rubber bushing on the torque tube, and saw the torque tube housing and VC are oily.
Posted 29 December 2011 - 03:03 AM
Posted 29 December 2011 - 01:08 PM
Posted 29 December 2011 - 02:28 PM
Posted 31 December 2011 - 03:53 AM
There's not much lubricant in there, so it won't leak for long. It's that's the case, it will fail shortly thereafter, but you will be well aware of it! Clunking on accel/decel turning, rattle like a ball bearing in a tin can, etc..
Posted 31 December 2011 - 01:06 PM
lookforjoe, on 31 December 2011 - 03:53 AM, said:
It was dark and the car was only jacked up in front. But it did look like it came out of the middle-rear section and got slung all over the gas tank from rotation. Today I'll get it up on all fours and get a better look. Probably going to remove the drive shaft and VC, too.
Posted 31 December 2011 - 11:04 PM
1. Rear CV on the driveshaft is not totally smooth like the front one. How much binding is acceptable? Front does not bind at all. Rear CV gets stuck at certain angles when playing with it.
2. When should I be able to turn the VC separately from the rear wheels? I thought if the rears were on the ground or parking brake set, I should be able to turn the front flange on the VC? Mine seems frozen as one unit.
3. To remove the VC and torque tube from the car: What's the best combination of tools and swedish curses to get those 8mm allen headed bolts (bottom of first and second pictures below) out of the VC flange that bolts to the pinion flange? I have an 8mm allen 3/8 drive socket, but there isn't room to get the socket wrench in there. I did PB blast them today so I can try them tomorrow.
Better pictures of the VC:
Posted 01 January 2012 - 03:20 PM
Posted 01 January 2012 - 03:37 PM
The VC/Freewheel should not be leaking, so you'll need to replace that as well. Use a hand held angle allen key to break them loose.
#14
Posted 01 January 2012 - 05:29 PM
lookforjoe, on 01 January 2012 - 03:37 PM, said:
It IS a Colorado rebuild that I just bought a couple weeks ago. I will be calling them for a free replacement.
#15
Posted 06 January 2012 - 01:57 PM
#16
Posted 07 January 2012 - 01:19 PM
Tyler T5R, on 06 January 2012 - 01:57 PM, said:
No.
#17
Posted 10 February 2012 - 02:55 AM
#18
Posted 10 February 2012 - 03:18 AM
