Diy Home Made Led Tail Lights, Anyone?
Posted 19 December 2011 - 03:21 PM
Here's a couple specific topics:
http://www.customfig...ead.php?t=49345
http://www.customfig...ead.php?t=47676
Could be kinda cool to have a symbol, or pattern behind the stock break lens.
Anyone tried this before?
"Turbobricks don't accelerate, they gain momentum" - Cox Man
Posted 19 December 2011 - 04:19 PM
volvo1911, on 26 March 2012 - 10:59 PM, said:
Posted 19 December 2011 - 05:11 PM
http://volvospeed.co...__fromsearch__1
Thanks, I was hoping to see some examples and toying with something on my own.
If you have any pics of your work though, I'd like to see em.
Posted 19 December 2011 - 06:12 PM
Here is video someone posted with a light I built. The LED's are in the shape of a "V" for "VRod" and it had a clear lens with integrated turn signals.
Basically all you need is a little perf board, superflux LEDs, solder, wire and resistors. All can be had from Radio Shack though I recommend getting the LED's from eBay.
Posted 19 December 2011 - 07:17 PM
Do you think you could make LEDs to custom fit in the s70 tail light for the break lights and the night time running lights? I use to own a mk2 gti and I had LEDs that filled the tail lights it looked really nice but I have never seen it done on the s70s and I think they would look really nice let me know what you think thanks.
Posted 19 December 2011 - 07:49 PM
Looks like Philips makes the Superflux, they also make Luxeon Rebel, have you heard of/tried these?
And what's the legality safety inspection standpoint on these, is there a certain lumens or something they have to hit?
Posted 19 December 2011 - 08:54 PM
BTW here is a link to a members 850 and 5mm round LEDs. Just to give you an idea.
http://www.hidplanet...highlight=volvo
Posted 20 December 2011 - 12:49 AM
trying to search google for it but it's been a while and I have no idea what it was called. not at home for 2 weeks.
I am planning to make them for my 240... I want to design/create the controller myself and add in some custom things, like a signal to tell my carpc when something is out, etc... I have a controller from an Accord or something, for brake/running lights, and it's a lot more than just a bunch resistors. need to study it, duplicate, and modify.
Brian
'91 244 (project: never-gonna-be-finished-because-im-fucking-lazy)
'04 S60 2.5T (dd/old man car) | '92 245 | '02 C70 2.3HPT Coupe
Posted 20 December 2011 - 01:13 AM
Brian
Posted 20 December 2011 - 01:22 AM
1999 Volvo V70 XC- Rebuilding as we speak...
Posted 20 December 2011 - 05:22 PM
the most modern GLT, on 20 December 2011 - 01:22 AM, said:
i had an 850 so everything i did was for them. but if u can find my old threads, i had quite a few of them as far as led work goes and hacking up the taillights and running a pwm to 'dim' the lights
850 Stuff for sale: 850r rear spoiler(601 classic red) $150shipped, misc pcv parts pm for inquiries !
Posted 20 December 2011 - 05:26 PM
Thorsteenster, on 19 December 2011 - 07:49 PM, said:
Federal laws make it illegal
Volvospeed On Google+
Posted 20 December 2011 - 05:29 PM
Che, on 20 December 2011 - 05:26 PM, said:
True but as long as "red" light is transmitted through a DOT lens you are not going to have any issues with State safety inspections.
#14
Posted 20 December 2011 - 05:45 PM
cheapwagon, on 20 December 2011 - 05:29 PM, said:
I think Chuck is referring to the fact that any modification to lights makes it illegal. So for instance, even if a proper headlight or tail light retrofit passes DOT tests and performs right, the act of modifying the light makes it not legal?
Either way, if done right, you should be fine. As long as you are not putting in tiny drop-in LED replacements that do not illuminate the assembly at all.
Serge - 95 850 T5
#15
Posted 20 December 2011 - 07:18 PM
97 850 GLT LPT 16T - EST Intake - EST Strut - Ferrita Exhaust - KW Coilovers - Undergoing S70/V70R front end retro fit ;)
04 S60 R - 6 MT - Titanium Grey - Nordcap - Sport Kit - Painted Trims - BBS CK 19x8 - CFW CF VST Front Lip - AEM Dryflow Intake - CFW PCC Spoiler - CFW CF Roof Spoiler - Clear headlights + 05+ Custom LED Tails - Eibach Springs - UltraRacing Strut Bar - Autovation Pedals - TWM Short Shifter + M1 Abrams Knob - 05+ Center Console
#16 Guest_luke_jones_*
Posted 20 December 2011 - 07:31 PM
#17
Posted 20 December 2011 - 09:21 PM
luke_jones, on 20 December 2011 - 07:31 PM, said:
Separating is a PITA. They are not glued with butyl adhesives like headlights (which you can heat and separate). They are similar to the front turn signals in these cars; they fuse the two pieces of plastic together using either heat or high frequency welding. If you find a way to separate them, please let me know, because I'm delaying my tail light retro (PWM controller done, PCB cut, SuperFlux LEDs ready, etc) because I don't want to cut things up just yet.
Serge - 95 850 T5
#18 Guest_luke_jones_*
Posted 20 December 2011 - 11:13 PM
After succesfully separating my front signals and inspecting the lower tails I will take the same approach I used before and report back. I evenly applied heat to my front turns and when I split the seam with a utility knife they popped open. I have a set of lower tails...I will do it and report back with pics. Then someone should send me uppers so I can create my full custom set.
#19
Posted 20 December 2011 - 11:41 PM
luke_jones, on 20 December 2011 - 11:13 PM, said:
You separated the front turn signals? PICS!
Serge - 95 850 T5
#20 Guest_luke_jones_*
Posted 20 December 2011 - 11:51 PM
I dont have pics of the signals apart, but I will do the exact same process to my lower tails and document. Then you can see how clean they come apart.
