Tpms Reset, 07 S80?
1 reply to this topic
#1 jl2
jl2
  • 232 posts
Posted 22 December 2011 - 09:54 PM
I replaced a TPMS sensor the other day (I used a Dorman replacement, specific for my model), but the "drive around for a while thing" isn't working. Is there another way to reset the TPMS warning? Thanks.
2003 S80, Non Turbo
#2 831t5r
831t5r
  • 375 posts
Posted 23 December 2011 - 12:28 AM
Tire pressures are above 36 psi right. If cycling the key after road tests and longer then 10 minutes, you can try activating the sensor using a tpms tool make sure its working. The drive it again so it recognizes sensor. Or you can use vida to program
95 850 T5-R - Sold : (
'00 V70R-STOCK/ ARD lightened Crank Pulley
'01 C70 Coupe - Stock
