Mutliple Issues: Instant Op Temp, Won't Stay Running At Start-Up, Etc.
Posted 23 December 2011 - 10:29 PM
Fast-forward to three hours later. Try to start it again, same thing. Once it started idling it would die, eventually able to drive it and everything appeared fine. Same as before, up to operating temp in maybe 30 seconds...according to the gauge.
About 5 hours later we try again. This time, it was sitting in the garage all afternoon so it was warm. Same thing. It would turn on, RPMs drop back down and it would die. This time, sitting inside we could define a couple things. One, operating temp again increased rapidly, after sitting for about 5 hours the gauge said it was at operating temp in maybe 5 seconds, engine was barely warm to the touch. Two, the throttle was extremely laggy. You would press the accelerator pedal and it would not rev up, very very laggy. Three, we were getting very strange boost/vac characteristics reving it. It was going INTO vac was the RPMs rose. See video:
Also, the IAC would run for a minute or two after the car shut off with the keys out. Don't know if that means anything, don't know if it's done that before. Could a bad IAC not cause the car to idle? Why would the gauge say it's at operating temp when it clearly isn't?
Any input or additional information/questions, please ask. This all started today.
1994 850 Turbo | Rica Stage III | Poke and Stretch
Posted 23 December 2011 - 10:57 PM
Replace with an OEM sensor and a new t-stat and she'll start right up.
Posted 23 December 2011 - 11:00 PM
Posted 23 December 2011 - 11:02 PM
Posted 23 December 2011 - 11:06 PM
And where is this located? Below the thermostat? How do I replace that?
Posted 23 December 2011 - 11:12 PM
gilber33, on 23 December 2011 - 11:06 PM, said:
Absolutely.
Yes. Search this site for ECT replacement. It's almost self explanatory.
Posted 23 December 2011 - 11:36 PM
Posted 24 December 2011 - 05:26 AM
1997 855R Black on Black, Bilstein HD's, IPD Blues, TITANS, 3" Custom Exhaust, Custom intake pipe
("insert funny quote here")
Posted 26 December 2011 - 10:21 PM
Posted 26 December 2011 - 11:13 PM
Posted 26 December 2011 - 11:23 PM
And, if the starter is completely fine, why would it not start when the car is still, but fire right up when it's rolling. And when I say crank like it normally does, I'm not talking about a powerful crank either, it's weak.
Posted 27 December 2011 - 12:46 AM
Basically, what would cause a car to not start when not in motion, but allow it to fire right up and drive 100% normal when in motion?
#14
Posted 27 December 2011 - 04:19 AM
#15
Posted 27 December 2011 - 04:40 AM
My Dad and I are also thinking maybe the ignition switch because of the description on FCP:
Quote
#16
Posted 27 December 2011 - 12:19 PM
Trying to determine other possibilities through the various sensors in the car. The crank position sensor I read that if it was bad will not let the car start but you would also lose spark, is that true? If so, I can cross that off the list.
Found these:
Quote
This sounds like it could be a possibility. The first thing my Dad said was that it sounds like the car wants to start, but there is something preventing enough electricity to actually start the engine (starter or ignition switch).
Quote
So I can rule out crank position sensor as I am getting spark.
Found Here
#17
Posted 27 December 2011 - 02:16 PM
Second time it was one of the coils..it would spark but it was too weak to fire. That was a pain to diagnose because there was visible spark..(this was on the trailing ignition on a rotory though, so i wouldn't suspect coil on yours if it pop starts)
Your starter idea may be accurate..
Edited by scumcity14, 27 December 2011 - 02:20 PM.
'05 xc/90. The stereo sucks.
#18
Posted 27 December 2011 - 03:01 PM
#19
Posted 27 December 2011 - 04:56 PM
#20
Posted 27 December 2011 - 05:11 PM
gilber33, on 27 December 2011 - 04:56 PM, said:
